Loose nut bhind the wheel
MFI Throttle stops
Help!! I sent some parts out to a local plating shop and they lost my throttle stops with the nuts. I think the size of the bolts are 5mm x.75 x18mm. Where can I get these or does someone have an old set of throttles that are no longer serviceable. They did send me two fender bolts for a Chevelle or something. Needless to say I am not happy about this situation.
Ed 1970 911S Targa 2.7RS MFI dual plug 10.5:1 1974 260Z SCCA ITS 1998 M3 |
Here's a (fuzzy) picture of the head, it's a cheese-head screw with the tip filed down.
McMaster has M5 x .8 x 20, are you sure that's not the thread pitch? As an alternative you can call Matt Blast or one of the guys who rebuilds them.
'66 911 #304065 Irischgruen ‘96 993 Carrera 2 Polarsilber '81 R65 Ex-'71 911 PCA C-Stock Club Racer #806 (Sold 5/15/13) Ex-'88 Carrera (Sold 3/29/02) Ex-'91 Carrera 2 Cabriolet (Sold 8/20/04) Ex-'89 944 Turbo S (Sold 8/21/20) |
Helllo John, where do you got the gauge from. Looking for this part since years. I only have pictures, like to rebuild them.
Can you help with some dimension details. Bob ![]() ![]()
Try not, Do or Do not
Henry Schmidt SUPERTEC PERFORMANCE Ph: 760-728-3062 Email: supertec1@earthlink.net |
I am pretty sure those are in vast supply here in metric land. If you still need them I will look tomorrow for you.
Cheers
Turn3 Autosport- Full Service and Race Prep www.turn3autosport.com 997 S 4.0, Cayman S 3.8, Cayenne Turbo, Macan Turbo, 69 911, Mini R53 JCW , RADICAL SR3 |
Thanks for the response. John it is definitely not .8 pitch as those are very common. Henry I will e-mail you. Jeff Thanks for your offer, let me see if Henry can put his hands on some easily. I asked the plating shop if they sent mine to someone else and they said that was impossible. I responded with"you sent me two GM fender bolts that were somone elses!!" Long silence on the phone.
Perhaps the largest selection of Porsche / Bosch MFI parts on the planet? Who knows.
The last law of business planning: Getting an ever growing percentage of an ever shrinking market is a blueprint for disaster. ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]()
Henry Schmidt SUPERTEC PERFORMANCE Ph: 760-728-3062 Email: supertec1@earthlink.net Last edited by 304065; 09-26-2007 at 07:51 AM.. |
