Loose nut bhind the wheel
MFI Throttle stops
Help!! I sent some parts out to a local plating shop and they lost my throttle stops with the nuts. I think the size of the bolts are 5mm x.75 x18mm. Where can I get these or does someone have an old set of throttles that are no longer serviceable. They did send me two fender bolts for a Chevelle or something. Needless to say I am not happy about this situation.
Ed
1970 911S Targa 2.7RS MFI dual plug 10.5:1
1974 260Z SCCA ITS
1998 M3
Old 09-25-2007, 09:32 AM
304065's Avatar
Here's a (fuzzy) picture of the head, it's a cheese-head screw with the tip filed down.
McMaster has M5 x .8 x 20, are you sure that's not the thread pitch?
As an alternative you can call Matt Blast or one of the guys who rebuilds them.
'66 911 #304065 Irischgruen
‘96 993 Carrera 2 Polarsilber
'81 R65
Ex-'88 Carrera (Sold 3/29/02)
Old 09-25-2007, 11:43 AM
HKZ Bob's Avatar
Porsche Crest
Helllo John, where do you got the gauge from. Looking for this part since years. I only have pictures, like to rebuild them.
Can you help with some dimension details.
Bob
Old 09-25-2007, 04:42 PM
Try not, Do or Do not
Henry Schmidt's Avatar
Originally Posted by eapcpa View Post
Help!! I sent some parts out to a local plating shop and they lost my throttle stops with the nuts. I think the size of the bolts are 5mm x.75 x18mm. Where can I get these ...............................
All things MFI, where else ? SUPERTEC
Henry Schmidt
SUPERTEC PERFORMANCE
Ph: 760-728-3062
Email: supertec1@earthlink.net
Old 09-25-2007, 06:04 PM
Jeff Alton's Avatar
I am pretty sure those are in vast supply here in metric land. If you still need them I will look tomorrow for you.
Cheers
www.turn3autosport.com
Old 09-25-2007, 06:48 PM
Thanks for the response. John it is definitely not .8 pitch as those are very common. Henry I will e-mail you. Jeff Thanks for your offer, let me see if Henry can put his hands on some easily. I asked the plating shop if they sent mine to someone else and they said that was impossible. I responded with"you sent me two GM fender bolts that were somone elses!!" Long silence on the phone.
Ed
1974 260Z SCCA ITS
1998 M3
Old 09-26-2007, 06:52 AM
Perhaps the largest selection of Porsche / Bosch MFI parts on the planet? Who knows.
The last law of business planning: Getting an ever growing percentage of an ever shrinking market is a blueprint for disaster.
Henry Schmidt
Ph: 760-728-3062
Old 09-26-2007, 07:34 AM
