I'm ready to do it!
Tomorrow morning, the case goes together. I know I seem to be making a lot of fanfare about this, but to a first time 911 engine builder, this is the first big hurdle. I checked my backlash tonight, it was .043mm or .0017". Probably getting close to the end of the tolerance, but I'm going with it, it's within spec.
One note that I'd like to make. I installed the "rear" main seal in the #8 bearing while it was free of the engine, and while putting it on the end of the crank, the pressure spring on the inside of the sealing lip popped out. So, one seal trashed. I pulled it, and after looking at it, I see the merit of installing the seals at both ends after the fact. This allows the builder to cock the seal in order to get the lip over the crank before pushing it into place. With the #8 seal installed in the bearing, you don't have much leeway to "rock it" onto the crank. The front seal at the flywheel probably could be done with the crank out, but I'll wait until the case is together to install the seals at both ends. Also, I got my heads and cam towers back from Ollie's tonight. Notice anything special about the heads (besides the Aasco racing springs and Ti retainers) ? ![]() ![]() ![]() ![]() ![]()
Ed Hughes 2015 981 Cayman GTS 6 speed,Racing Yellow Past:1984 911 Targa (Ruby), 1995 993C2 (Sapphire), 1991 928S4 |
Oh yeah...
So which ignition setup are you going with? I've always said that two holes are better than one.
-Troy 88 3.4L Coupe |
Well, THAT will be a bit further down the road, next year, when I move to the land of 91 octane. But, I'm leaning toward the Andial splitter setup.
I am going with a 964 distributor and the Andial splitter. It's on the way now. Look for my 3.4 build thread coming soon to a forum near you...
Cool, keep us posted on the ignition setup.
Ed, I want to see some pics of that sucker sealed up tomorrow night when I get home!
![]() Good luck, it will go fine I am sure, you look pretty prepared. Cheers
Turn3 Autosport- Full Service and Race Prep www.turn3autosport.com 997 S 4.0, Cayman S 3.8, Cayenne Turbo, Macan Turbo, 69 911, Mini R53 JCW , RADICAL SR3 |
Ed,
Mind if I stop by this afternoon to see how your project is progressing? If so it will be after 1PM, Renee is out till then and one of my boys is sick. Marco
96 993 coupe 88 911 cab (gone, but not forgotten) |
see you soon
GAFB
Really? I've had that happen and have just reinstalled the spring and forged ahead. Is that a no-no?
Several BMWs Last edited by dtw; 09-22-2007 at 11:15 AM.. |
Couldn't get the spring in with the seal in the bearing. Couldn't/wouldn't take the seal out and try to reinstall without hosing up the seal, so I'm just getting a new one.
Congratulations! I love reading these threads; still on the fence whether I want to try or will work with someone who has vast experience, but hats off to you for taking on the project.
Matt West 1980 911 SC |
abit off center
I am using the splitter in my 3.4, If you go that way is SW doing your chip?
______________________ Craig G2Performance Twinplug, head work, case savers, rockers arms, etc. |
Absolutely. I've had a Steve W chip in my car for it's full evolvement. When I twin plug, Steve will be sitting at the dyno with his laptop tuning it....
What sealant did you use on the case halves?
Threebond 1104 around the perimeter, Loctite 574 on the webs and Dow 55 on the thru-bolt o-rings. Oh, and Threebond 1211 on the nose bearing.
