Newbie Question 1989 Carrera 4
Has anyone put a turbo in a 1989 Carrera 4?
Old 09-28-2007, 08:09 PM
BReyes's Avatar
Are you thinking about going rallying? Or do you just want to do Rennsport III in style?
The motor would need to be rebuilt, and in doing that and sourcing/installing a kit (single or TT) including tuning requires you are a PCar wiz or spend some money. You could buy a turbo and be done.
First rule is always to set a budget from the start.
Its a sweet car either way, turbo or not.
Bernard
Old 09-29-2007, 02:10 PM
Try not, Do or Do not
Henry Schmidt's Avatar
I advise is to sell you normally aspirated engine ($5.5-$6.8K) and buy a turbo engine.
Which turbo engine you buy will be determined by your budget and only your budget.
Almost anything you want (78-89 3.3, 91-92 3.3 C2 turbo, 94-95 993 3.6 single turbo or the 996 twin turbo) can be installed in your chassis.
There are also many tuners in the Porsche world that can build monster turbo engines to fit your project.
For my money I would go with a 996 twin turbo. They are out there for around $17K. Plan on another $3K-$5K for installation.
Henry Schmidt
SUPERTEC PERFORMANCE
Ph: 760-728-3062
Email: supertec1@earthlink.net
Old 09-30-2007, 07:28 AM
Henry,
where would you mount the rads?
Old 09-30-2007, 08:49 AM
Oil cooler in the right front fender and water (ick !) radiator in the left front fender.
Henry Schmidt
Ph: 760-728-3062
Old 09-30-2007, 09:08 AM
I would think the turbo from this year might work
91-92 3.3 C2 turbo
any info or pics of the mounting of the rads?
Old 10-09-2007, 12:22 AM
I mean I can do a turbo swap in a vw 16valve and switch out the bottom to a bigger block ..blah blah blah...(dont laugh at me) im no master mech. but I am not sure whats involved going from air to water..
Old 10-09-2007, 12:24 AM
kirkf's Avatar
I would install a supercharger.
Kirk
1989 911 Carrera 4 (964)
Old 10-09-2007, 05:51 PM
