thanks ,
I'm flying to NJ from the UK on Sunday so I will try and pick one up...just for "Garage tool Stock" ;-) I can see you having some intresting times.....I did with my 964 rebuild. Posted on Pelican as well, and should be in the Jan 08 edition of "Total 911 magazine"...a Pelican sponsor as well. Ian |
Hi
I don't know if this has been mentioned in any other threads -propably has... After I changed the exhaust on my 911 I realized broken studs is not that big of a deal, sounds corny i know, but I read about something called EDM (electrical discharge machine) in Waynes 101 projects book, accidently broke a stud an couldn't get it out, tried it all from heat to snap-on. I consulted the 101 again and started a search on the EDM stuff. coincidently my farther worked at Vestas (the windmills) and they had this machine. we removed the broken stud in about 30 minutes, no sweat at all. We had never tried it before, just borroved the equipment. The thing is the EDM itself is not that common so it may require at little search. Hope the story is OK (no thread steeling) best of luck with your rebuild, I will be joining you soon. jesper |
It would be immensely more convenient if an EDM setup could work on the car .... and upside down. The inconvenient part of stud removal with EDM is the process of removing the cylinder head just to access the stud.
Sherwood |
Aurel,
U have a private msg. SmileWavy |
Update: I borrowed a bore gauge from work, and I measured my cylinder diameters at 30 mm from the upper edge, as Wayne book says.
Here are the values: Cyl# d(mm) 1 95.0722 2 95.0468 3 95.0595 4 95.0468 5 95.0468 6 95.0341 They all have less than 0.08 mm wear, so I can reuse them, right? The ring groove clearances on the pistons were all within specs, even with the old rings. What else should I measure? Aurel |
You could measure each cylinder 90º from your first measurement. That would provide an out-of-round measurement to compare with spec.
You could measure the bottom of the cylinder in a non-wear area to establish the unworn bore dimension, then compare with your top measurements. That would provide a taper spec. Use an outside micrometer to measure the piston OD (about 30mm above the bottom of the skirt). That would provide the piston diameter and a piston-to-cylinder clearance spec when that dimension is subtracted from the cylinder bore measurement. Same with piston pin bore and OD. Sherwood |
0.08mm seems like a lot... isn't that something like 0.003" what is the spec.?
Edm
Hi
thats's the good thing about it. The EDM was a portable system. Did it with the engine in the car - Upside down...;) Regards Jesper |
Some pictures: I got my renewed heads from Bob, he did a beautiful job. I repainted my fan shroud, sand blasted exhaust, shiny heat exchangers, rebuilt 915...things are shaping up.:)
http://forums.pelicanparts.com/uploa...1196392106.jpg http://forums.pelicanparts.com/uploa...1196392375.jpg Aurel |
any update on progrress?
I hope all is going well... my guess a delay was/is being encountered...? Bob |
Garage is cold, but progress has been good. I sealed the long block, got my camshafts back reground to DC15 profile. Next is chain boxes, cam timing, reassembling the rockers. I still have to order the `piece of mind` chain tensionner update from our host and I`ll have all the parts I need. I decided not to split the case. Delay is mostly waiting to see how my tax return will look like...
http://forums.pelicanparts.com/uploa...1201404202.jpg http://forums.pelicanparts.com/uploa...1201404236.jpg Aurel |
For memo, here is the list of all upgrades done once it will be finished:
- All lower headstuds replaced with factory stainless steel. - Heads professionally rebuilt. - Gearbox professionally rebuilt. - New rings and scotch brite honed Alusils that were in specs. - Camshaft renewed to DC15 profile. - Camshaft oil restrictors. - Rocker shafts RSR seals - New chains, ramps. - Updated idler arms. - Hydraulic chain tensionners. - Replace cracked fan housing. Then, and only if all works well (good rings seating, no oil leaks...), I may treat her with SSI heat exchangers. Aurel |
I would have split the cases...you have put a lot of effort in and its minimal to go the next step...I heard of one engine 964 ...rebuilt like yours, 4K later the bottom bearings went ...a right off. I brough some of the parts for my rebuild.
I thought I might do what you did..see my thread as I went the whole way. Peace of mind. Ian |
signing on seems like a great thread on info ...thanks Angel
Would an oil analysis ahead of time be able to tell you if you have problems with the mains or layshaft bearings?? Cheers, Mike.
Reporting progress: Cam timing is done, details here: http://forums.pelicanparts.com/911-engine-rebuilding-forum/396936-cam-timing-valve-piston-clearance.html
Carrera tensioners installed, rockers with RSR seals, valve gap set, Long block is sealed, I am still looking for a replacement fan housing and few minor parts. Maybe one more month to go at my very leisurely pace... http://forums.pelicanparts.com/uploa...1205614370.jpg http://forums.pelicanparts.com/uploa...1205614258.jpg Aurel |
Looking good!
I put the exhaust back on tonight. No SSIs before she proves she deserves it...
http://forums.pelicanparts.com/uploa...1205895603.jpg Aurel |
Tip for you, with a S/H exhaust
HI Aurel
I see you have fitted the exhaust with the engine upside down, I only hope there was no loose carbon in the ports and the exhaust was clean in side as it is out side, speaking from experience and I only fitted the exhaust like that the once, the loose carbon fell in to the exhaust ports and in to the engine giving it a miss fire on start up with carbon on a valve seat, the engine had to be striped and the valve/seat sorted, and I never fit the exhaust like that now, only 90deg and push it on , no hammering to make it fit, just in case. I hope your is OK and not a prob' with the amount of work and effort you have put in to it . regards mike |
Hi Mike,
I ran my shop vacuum in the exhaust manifolds to suck up any possible debris. It looked as clean as can be...But you`re right, point well taken. Aurel |
I was looking for a used fan housing since mine is cracked. But I discovered that the 225 mm one that I have is a lot cheaper than a 245 mm. So I ordered a brand new one from our host ($246 versus $649 for a 245 mm). That and the larger intake ports are some of the sweet specificities of the 78 SC.
Aurel |
Damn, I am back to square one; it was too nice to be true:
Unfortunately, we recently discovered that one or more of the parts you ordered are No Longer Available (NLA). These are: OEM-93010600500 Fan housing Brand: Genuine Porsche***NLA Still looking for a 225mm fan housing then... Aurel |
Go used. Parts Heaven, DC Automotive, others.
That I have. I put a bid on this housing, though:
It looks terrible, but if I get it for cheap, I will sandblast it. Aurel |
Senior moment. Sorry.
I saw that one, but I already made a deal with this pelican member:
http://forums.pelicanparts.com/porsche-911-used-parts-sale-wanted/391373-930-fan-housing.html I know the 930.106.102.0R can replace my 930.106.101.0R. It looks in very good shape, I hope my problem is solved. Aurel |
Okay, now that my fan problems are solved (details: http://forums.pelicanparts.com/porsche-911-technical-forum/402155-226-mm-fan-245-mm-housing.html ), I can finally report some progress:
http://forums.pelicanparts.com/uploa...1207971950.jpg http://forums.pelicanparts.com/uploa...1207971990.jpg The CIS goes back on tomorrow, but I am wondering if I should replace hoses on it , and what other maintenance I could do on it while all is accessible? One more thing, I can`t remember what the purpose of these two brackets was...any idea? http://forums.pelicanparts.com/uploa...1207972166.jpg Aurel |
those brackets are to facilitate mounting the heater blower motor a/o its hoses in the engine bay.
If you do a parts schematic looking at the heater blower motor in the engine bay you'll see them. Keep up the great work amd posting on your progress. Bob |
Cleaning up the CIS system, the injectors and intake pipes are a bit dirty. Is it okay to spray them with brake cleaner?
Aurel |
I'd send your injectors out for cleaning, testing. You'd be surprized how dirty they are.
http://forums.pelicanparts.com/uploa...1208036054.jpg Aurel |
I cleaned my injectors by using a rubber hose about a foot long clamped to the threaded part of the injector. I then set my compressor to about 60 psig and used a rubber tip air nozzle to clean the injectors. You can fill the hose with what ever cleaner you want and view the spray pattern. I have used ultrasonic cleaners in the past and have not been happy with the results.
I am getting confused about these injectors: are they purely mechanical, or do they need electrical pulse to open? On the other hand, I don`t see where I would connect wires on them, so they look only mechanical to me. Someone please enlighten me on the 3.0 CIS injectors SmileWavy. Aurel |
The CIS injectors are entirely mechanical. I used the same technique to clean mine as Matthew. I also figured out how to backflush them (but I question whether it's worthwhile).
Brian |
Here are my injectors after ultrasonic bath of propanol, then trichloroethylene, then methanol flush with compressed air. This was the highlight of my working day in the chemistry lab :cool:. All had a good spray. Thay can`t be worse now than they were before...
http://forums.pelicanparts.com/uploa...1208230176.jpg Aurel |
How nice of the university to give you that equipment to use! The injectors look great. How is the spray pattern?
| All times are GMT -8. The time now is 06:48 AM. |
