Hi Mike,
I ran my shop vacuum in the exhaust manifolds to suck up any possible debris. It looked as clean as can be...But you`re right, point well taken. Aurel |
I was looking for a used fan housing since mine is cracked. But I discovered that the 225 mm one that I have is a lot cheaper than a 245 mm. So I ordered a brand new one from our host ($246 versus $649 for a 245 mm). That and the larger intake ports are some of the sweet specificities of the 78 SC.
Aurel |
Damn, I am back to square one; it was too nice to be true:
Unfortunately, we recently discovered that one or more of the parts you ordered are No Longer Available (NLA). These are: OEM-93010600500 Fan housing Brand: Genuine Porsche***NLA Still looking for a 225mm fan housing then... Aurel |
Go used. Parts Heaven, DC Automotive, others.
That I have. I put a bid on this housing, though:
It looks terrible, but if I get it for cheap, I will sandblast it. Aurel |
Senior moment. Sorry.
I saw that one, but I already made a deal with this pelican member:
http://forums.pelicanparts.com/porsche-911-used-parts-sale-wanted/391373-930-fan-housing.html I know the 930.106.102.0R can replace my 930.106.101.0R. It looks in very good shape, I hope my problem is solved. Aurel |
Okay, now that my fan problems are solved (details: http://forums.pelicanparts.com/porsche-911-technical-forum/402155-226-mm-fan-245-mm-housing.html ), I can finally report some progress:
http://forums.pelicanparts.com/uploa...1207971950.jpg http://forums.pelicanparts.com/uploa...1207971990.jpg The CIS goes back on tomorrow, but I am wondering if I should replace hoses on it , and what other maintenance I could do on it while all is accessible? One more thing, I can`t remember what the purpose of these two brackets was...any idea? http://forums.pelicanparts.com/uploa...1207972166.jpg Aurel |
those brackets are to facilitate mounting the heater blower motor a/o its hoses in the engine bay.
If you do a parts schematic looking at the heater blower motor in the engine bay you'll see them. Keep up the great work amd posting on your progress. Bob |
Cleaning up the CIS system, the injectors and intake pipes are a bit dirty. Is it okay to spray them with brake cleaner?
Aurel |
I'd send your injectors out for cleaning, testing. You'd be surprized how dirty they are.
http://forums.pelicanparts.com/uploa...1208036054.jpg Aurel |
I cleaned my injectors by using a rubber hose about a foot long clamped to the threaded part of the injector. I then set my compressor to about 60 psig and used a rubber tip air nozzle to clean the injectors. You can fill the hose with what ever cleaner you want and view the spray pattern. I have used ultrasonic cleaners in the past and have not been happy with the results.
I am getting confused about these injectors: are they purely mechanical, or do they need electrical pulse to open? On the other hand, I don`t see where I would connect wires on them, so they look only mechanical to me. Someone please enlighten me on the 3.0 CIS injectors SmileWavy. Aurel |
The CIS injectors are entirely mechanical. I used the same technique to clean mine as Matthew. I also figured out how to backflush them (but I question whether it's worthwhile).
Brian |
Here are my injectors after ultrasonic bath of propanol, then trichloroethylene, then methanol flush with compressed air. This was the highlight of my working day in the chemistry lab :cool:. All had a good spray. Thay can`t be worse now than they were before...
http://forums.pelicanparts.com/uploa...1208230176.jpg Aurel |
How nice of the university to give you that equipment to use! The injectors look great. How is the spray pattern?
| All times are GMT -8. The time now is 09:28 AM. |
