Hey Aurel!
Greetings from norway. ...-Nice job! I'm doing a rebuild myself, and this causes many sleepless nights... (As I'm sure you have discovered) ...So it is nice to see someone has been there, and knows what to do! Hope you will get it fired up real soon..! |
Free minder
Good luck Otto ! I did it in 6 months, really taking my time, and it was a very enjoyable experience. Post a thread here, with lots of pictures, and you will get all the help you may need. Some of the folks on this board are really very experienced, and we all love to share what we have learnt.
Best, Aurel |
Aurel:
I just came to think of something I read in the tech artichles here. http://www.pelicanparts.com/techarticles/911_engine_rebuild/911_engine_rebuild1.htm ...(Scroll to the bottom) He had a similar problem, and concludes it just takes time to get all the air out of the system, before the CIS can build up preassure to the injectors... (But you say there is no action in the fuel pump, right?) Last edited by otto in norway; 05-06-2008 at 04:37 PM.. |
Free minder
Tonight, I removed the belly pan to access the fuel pump, and connected the battery directly to it. I heard something, but it was a buzzing sound coming from the fuse box, not the pump. This pump is gonna have to come out...
Aurel |
Retired Member
Sounds like the pump is tired. I would try bench testing it before dropping the cash for a replacement.
A new pump will give you peace of mind when you are enjoying a drive a 1000 miles from home.
1982 911 SC Targa - Rosie....my Mistress. Rosewood Metallic on Dark Brown and Black. Long distance road warrior and canyon carver. A few mods - a little interior, some brakes, most suspension and all of the engine. |
Free minder
Yes, tonight I am going to check that 12V goes to the pump when I lift the air sensor plate, and I will measure the current draw to the pump, and its internal resistance. Just made a cable for that
.Aurel |
Ambitious Outsider
Aurel is your fuel pump dead? Have you started your ride??
1988 3.2 Cab 2005 997.1 C2S |
Free minder
Yup, fuel pump is definitely dead. It gets the voltage and does not spin. It was on its last leg before I started the rebuild. No big deal, just more delay...
Aurel |
Funny how these things happen, huh?
It worked when you started the rebuild, and when your'e finished, it quits on you..!? -Murphy's law... |
Ed Hughes 2015 981 Cayman GTS 6 speed,Racing Yellow Past:1984 911 Targa (Ruby), 1995 993C2 (Sapphire), 1991 928S4 |
I have a fuel pump from a 3.2 that
hasn't been used in years. Not sure if they interchange...? If you want it, you are more than welcomed to it. I'm usually down in that area once a week. - Great thread.!. -
87 911 97 993 prior p-cars: 76 912E 85 targa |
Free minder
Aurel Last edited by Aurel; 05-09-2008 at 01:39 PM.. Reason: peace of mind, not piece of mind, duh! |
Free minder
While waiting for my new fuel pump to arrive, I repainted by bumpers with a special flexible paint for plastics. It looks a lot better now, and if this paint holds up well, I can renew all my weathered black rubber pieces like that...
.![]() Aurel |
great thread! i was just helping a friend out sorting his CIS and pump issues, we had a similar problem - the pump was spinning, but no fuel output though we had gas and all the lines were clear. he's using a walbro too. problem? wired backwards, pumping the wrong way. funny how simple things can cause large headaches, eh?
keep us posted, of course |
Ed Paquette 1983 911SC 1987 944S 1987 944 Manual (Donated to the Nat. Kidney Foundation) 1987 944 Automatic (Recently sold to another Pelican) |
I have been told that these pumps often sieze up when they are left dry ( ie. did you drain the tank ? ). Apparently the idea is to keep them wet with fuel or similar.
I've had two fail when the tank was drained. One the period of time was many years, the other only a month. The latest one I connected power in reverse and it freed up, and then worked in the normal direction. You could feel the pump give a little kick when power was applied when it was siezed.
Earlysport _____________________________________ 69 911E, 69 911E RS Rep 3.0L Hotrod, 77 930 IROC REP 3.6L SOLD, 968CS SOLD, 987 Boxster S SOLD |
Free minder
The power in reverse is a great idea, should have tried that before ordering a new one! Oh well, at 110,000 miles it was getting tired regardless.
Aurel |
Loving the thread - keep up the good work. |
Free minder
New pump is here, weather is cooperating (outside is better for gas fumes). I`ll be doing the surgery later today...any last minute advice?
![]() ![]() Aurel |
Free minder
Allright, the pump replacement went fine. I now have gas spraying through my injectors. I also have spark. But when I crank, nothing happens. Not a sputter, nothing. The part that worries me is that when I crank with the fuel pump relay removed, I hear a few pops through the pop-off valve??
Could my static ignition timing be so far off? Can I set it to 5deg past tdc with the timing light while someone cranking the engine with no fuel?. Or, can I try to move the distributor while someone is cranking with fuel to try to get it to start...? I cannot imagine my cam timing would be wrong, but maybe I have the distributor off by 180 deg? Aurel |
