Fully threaded head studs - what are they?
In the process of tearing my engine down. I have the heads off, but not the cylinders yet. Best I can tell, the whole stud is threaded? I wasn't expecting that. Any idea what iteration of head studs I might have? I'm pretty sure they were replaced at some point in the engine's life.
Todd
'81 SC |
I believe that would be 993 Dilivar. Which is a good thing.
No left turn un stoned |
yup, off the 993 models.
Porsche 2005 GT3, 2006 997S with bore-scoring Exotic: Ferrari F360F1 TDF, Ferrari 328 GTS Disposable Car: BMW 530xiT, 2008 Mini Cooper S Two-wheel art: Ducati 907IE, Ducati 851 |
So, definitely reusable? I was hoping to have the case tumbled to clean it up. Maybe just hot tank it then?
Todd
'81 SC |
Schleprock
Actually 993 twin turbo. Regular 993 are all 24 steel studs.
Steve Weiner is a big proponent of these 993TT studs for performance usage. They're the latest and greatest iteration of Diilvar studs and that's supposed to be a good thing.
Kevin L '86 Carrera "Larry" |
These are the good ones, used on 993RS and 993tt
Looking through some paperwork that came with the car. Looks like these used to be part number 93010117002. Superseded with part number in the pic above.
Todd
'81 SC |
Nope, the .02 studs are also fully threaded but were used on base 993
Still good, or recommendation would be to replace them?
Todd
'81 SC |
Forced Induction Junkie
My $0.02, replace 'em. Use a good aftermarket stud (Raceware, Supertec, etc.). The ".52"'s are outrageously expensive.
I put the .52's in my rebuild (2002) before the prices went through the roof. No problems with them ever.
Dave '85 930 Factory Special Wishes Flachbau Werk I Zuffenhausen 3.3l/330BHP Engine with Sonderwunsch Cams, FabSpeed Headers, Kokeln IC, Twin Plugged Electromotive Crankfire, Tial Wastegate(0.8 Bar), K27 Hybrid Turbo, Ruf Twin-tip Muffler, Fikse FM-5's 8&10x17, 8:41 R&P |
Schleprock
Actually the Dilivar stud that is 930.101.170.02 was the smooth style only threaded at the ends. The 911 turbo engines have always had all 24 studs in dilivar flavor. That 930 part number is currently superseded by the 993 all-thread ending in .53
The all-thread appears to have arrived with the 965 3.6 turbo engine around 1993-1994. They used 12 of the regular 930 dilivars and 12 of the all thread (ending in .51). A noteworthy aside here is that the 964 engines (even the 965 3.3 turbo) used 930 dilivar studs for all 24 studs. Then the 993 comes along and the regular 993 gets steel studs p/n 993.101.171.02 (now superseded to .03 which is also steel). I have these 993 steel studs on my "race" engine, which I bought from Pelican last year. Then the 993RS and 993TT come along and they get all-thread dilivars for all 24 studs. Weird how the dilivar usage hops around on these engines, isn't it? We might be interested to know what the 996TT uses, since that engine is based on an air cooled case. It uses 24 studs that are p/n 996.101.172.70, which coincidentally are the same studs the GT3 uses. They're fairly cheap @ only $17 each. So they must be steel? I suspect the water cooling negated the need to install the dilivar studs.
3 restos WIP = psycho
Damn - cheapest I can find them is $38/ea. $900 for 24...doh! Pelican Stock
- 1965 911 - 1969 911S - 1980 911SC Targa - 1979 930 |
Schleprock
Makes the Supertec studs a bonafide bargain, doesn't it?
I bought the Supetec head studs. They are art.
Todd
'81 SC |
The subject of head studs has been debated in this forum for many years and prices just seem to keep on increasing.
Standard steel studs are around $400 a set with nuts and washers. Good Quality aftermarket studs seem to average at around $650 a set The latest 993 Dilavar parts are $1500 without nuts and washers. All of this for a stud with a torque of 24-25 lbsft. Grade 8.8 bolts can be safely torqued to 34 lbsft so I wonder why we need to use ultra-high strength super alloys that were developed for the hot sections of Gas Turbines when simple bolts will probably do the job. 4 feet of a Grade 8.8 All thread has a cost of about $4 and would make 6 studs so 24 studs would be less that $20. Seems quite good value. Grade 10.9 all thread is about twice the price an even so cost would be less than $50 per engine. Seems like quite a good saving
RGruppe #180 So many cars.. so little time!! |
Ingenieur
There is no reason why a Grade 8.8 Steel would expand any more than the standard steel stud. The Coefficient of Expansion of most engineering steels are within 1-2% of each other and this variation is negligible.
Dilavar expands around 50% more than ferritic/martensitic steels and and they don't lose preload - at least until they break. The description used by our Host for 993 studs is as follows: 993 - fully threaded, DILAVAR, 911/911 Turbo (1965-98) I was trying to have a discussion on why we all believe the more exotic the material the 'better' the stud when in fact the application is not particularly demanding in terms of metallurgy. My old 500cc (Single) Velocette Venom Thruxton used to produce around 45 BHP which is equivalent to 270BHP from a 3.0 litre and it had 4 really cheap studs that were nothing special. Manx Nortoms produced around 55BHP in 1963 (330 BHP equivalent) and again used 4 x simple studs. Today with all of the modern advances we seem to need $1000 of high end Precipitation Hardening Superalloys to do the same job that was done in the Sixties with materials that were not much better than mild steel. I guess this is what we call progress.
