Free minder
.Aurel |
You are making good progress.
If'n it was me, I'd put it togeather and before I fire it up test the injectors by putting them in 6 glasses and run em for 1/2 glass full. Compare and if one seems bad, swap it and test again. That will tell you if you have a bad injector.
Old Tee all 911s sold |
Free minder
I am getting closer and closer...I estimate I am about $200 away from completion now. Little stuff like hoses, sound pad, accelerator bushings, etc. I managed to reconnect the gearbox and put the motor back on the ATV cart all by myself tonight. Gotta work on the engine compartment tomorrow
.![]() ![]() Aurel |
HI Aurel
Do not forget the oil breather pipe on the top of the engine and turn the exhaust clamp round before you fit the engine, 1 it will catch the rear valance under the bumper when you fit the engine and 2 you will not be able to remove it when you have the engine in. regards mike
Regards mike 1983 911 SC sport, 1982 mini city |
Free minder
Hi Mike,
Thanks for the exhaust clamp. It is nice to have another set of eyes watching for my errors! The oil breather hose was dried, it is on my last order list. Regards, Aurel |
Now you have no reason not to paint the car!
Free minder
Yup...funny where a few broken headstuds can get you
.Now, I have a few questions: #1:On the picture below, there is a black connector from the wiring harness that I have no idea where it goes. I was pretty good at marking everything, but this one was unmarked. Maybe because it was not connected in the first place. What is it? Anybody got an idea? ![]() #2. I need to replace one of my heat exchanger to fllapper box hoses. I want to match the good one, but I do not know if what I have is the OEM or the "space age" pelican sells. Below is a pic of the good one: ![]() Thanks guys, Aurel |
HI Aurel
this is a UK 3.0lt engine with the black connector hanging out the back like yours ![]() it fits on the AAV hear. Your wiring loom should go under the intake manifold and not round the back of the engine, should come out near the No'1 intake manifold runner, to plug on to the 14 pin connector? ![]() in there on the black connection ![]() the heater pipe you require is red heat resistant, the one on your car looks black?, and should be this length for your Pass' side and shorter for your Drivers side to fit on the temp sensor connector for the heater control. ![]() the is a after market one we get over hear and the Porsche part No' is below the Euro car parts No' ![]() regards mike
Regards mike 1983 911 SC sport, 1982 mini city Last edited by MBEngineering; 04-20-2008 at 08:29 AM.. |
Free minder
Got it. Mike, you`re da man !
Aurel |
Free minder
Well, that is it, the motor is back in the car. I`ll fire up tomorrow if all goes well. I still have a few things to connect. I am wondering where to plug the connector in the second picture, and I have no clue what connects to the two connectors on the corners of the car like the one on the third picture. Any help will be appreciated!
![]() ![]() ![]() Aurel |
The three pronged plug in the second picture is for an old style voltage regulator. Looks like you updated. Cover it up with tape and if the little green (or is it red) light goes out on the instrument panel you are chargeing.
Remember to turn it over with the starter withoiut starting until you get oil pressure. Leave out the fuel pump relay. Also don't forget to charge the fuel system. Remove the line to the WUR and raise the lever in the air box and when you get fuel, hook it back and go driving.
Congratulations are in order! Good for you.
Do you remember if the machinist left any marks on the cylinder heads to address the amount machined? Just wondering, since I am in the process of rebuilding my 1978 911SC 3.0L. Have fun with the car on it's second-in-life first drive and break-in.
Ed Paquette 1983 911SC 1987 944S 1987 944 Manual (Donated to the Nat. Kidney Foundation) 1987 944 Automatic (Recently sold to another Pelican) |
Retired Member
+1. Great thread. Congrats.
1982 911 SC Targa - Rosie....my Mistress. Rosewood Metallic on Dark Brown and Black. Long distance road warrior and canyon carver. A few mods - a little interior, some brakes, most suspension and all of the engine. |
Free minder
Aurel |
Free minder
Need your help again...Hoses are as much trouble for me as hoes are for gov. Spitzer !
In the picture below, there is a ~1 ft hose, 5 mm diam. that connect to the T black plastic connector one the side indicated by an arrow. Where does this hose go ? ![]() Aurel |
Free minder
So, I filed with 9.5 quarts of 10W30 castrol GTX, and started cranking. All sounds normal, the green light went off, the pressure indicated went up to ~ 1. Is that enough?
I am not firing yet, because I have 2 issues: - I still don`t know where to connect one CIS hose (see above). - I have only 0.5 gallons (4 pints) of swepco 201 in my gearbox. Do I risk to damage it if I go drive like that (it was just rebuild, and the mechanics said to put 7 pints in it). I am itching to fire it up, but I don`t want to screw things up so close... Aurel |
Hope these help.
Free minder
I could try to start it, and do a static break-in, but with rering alusils, I read best results are obtained by driving the piss out them right away, so I should wait. Would it hurt to just try and see if it fires up, then shut it off immediately...? Aurel |
Retired Member
I would fill the tranny before starting the engine.
Sorry - not 100% sure about that hose.
