twin plug info
What brackets are out there for running twin coils for twin plug dizzy? I would like something that looks some what period correct.
Also what needs to modded for the back dated heat duct for the 12 plug cap? Any pics?
thanks guys
Ben
89 944,85.5 944
914-6 2.4s GT tribute.
914-6werkshop.com
Old 10-04-2007, 01:47 PM
Ben
I used the coil brackets that came with the MSD Blaster coils.
Tom Butler
1973 RSR Clone
1970 911E - Sold but Never Forgotten
914-6 GT Clone
Old 10-04-2007, 02:12 PM
what about the heater duct mod? any?
Ben
89 944,85.5 944
914-6werkshop.com
Old 10-04-2007, 02:32 PM
I used the fiberglass heater backdate piece available from Smart Racing.
Tom Butler
1973 RSR Clone
914-6 GT Clone
Old 10-04-2007, 03:07 PM
Try not, Do or Do not
Henry Schmidt's Avatar
Originally Posted by mb911 View Post
edit..........................Also what needs to modded for the back dated heat duct for the 12 plug cap? Any pics?
thanks guys
The left side turbo air duct works as well as anything, and looks correct. You can also modify a early duct to work.
Be careful with how you mount the Blaster II coils. They are oil filled and if you mount them vertically or up-side-down they will leak and fail. They can actually catch on fire.
That is why we stopped using the Blaster II and now only use the Blaster SS.
BTW: your Supertec Gen I twin plug distributor and wires shipped today. Enjoy. Remember, lots of pictures
Henry Schmidt
SUPERTEC PERFORMANCE
Ph: 760-728-3062
Email: supertec1@earthlink.net
Old 10-04-2007, 03:23 PM
Loose nut bhind the wheel
If you are keeping your heat you need to use the turbo part or modify your own. If you do not need heat in the car, use the backdate kit. I need heat so I modified mine based on a picture Henry posted for me. This is mine.
Ed
1970 911S Targa 2.7RS MFI dual plug 10.5:1
1974 260Z SCCA ITS
1998 M3
Old 10-05-2007, 09:46 AM
E-85 sippin drunk
turbobrat930's Avatar
I have got one for sale from a turbo, as I am not going to be using heat anymore... 30 bucks plus shipping..its yours...
Brad...930 gt-1 racecar, increased displacement to 3.6L, JB racing Cylinders, JE 8 to1 pistons, stroked crank, Carrillo rods, extrudehoned 3.2L intake, full bay Bell I/C, GT-2 EVO cams, Rarly8 headers, GTX-3584RS turbo, twin plug, P&P heads, Link G4 EFi system, G-50/50 with LTD slip and oil squirters/oil cooler, zork tube, full race coilover system, with carbon fiber body, full cage, E-85 sippin drunk
Old 10-05-2007, 10:33 AM
Thanks guys for the pics and help. i of course will modify my own simply because I can.. This helps a bunch and henry I will post tons of pics thanks again
Ben
89 944,85.5 944
914-6werkshop.com
Old 10-05-2007, 01:30 PM
iamchappy's Avatar
Henry, dont you mean horizontally. I would think having them vertical with the top facing up would be the safest way....
914 6 Turbo twinplug 3.12
87 924S
Lexus SC400
Lexus LS400
Old 10-05-2007, 07:02 PM
I would rather be driving
jpnovak's Avatar
Ben, are you going to trigger and time through the MS box? I want to do this and then route through a 12 plug dizzy. Modern electronics with vintage appeal.
Old 10-05-2007, 07:29 PM
The distributor was custom built for Bens engine. The advance curve and retard were designed to match his engine specs. The only thing needed at this point is a CD or two and right foot pressure.
Henry Schmidt
Ph: 760-728-3062
Old 10-05-2007, 10:13 PM
Look what turned up in the mail saturday.. It will take some time to make progress currently I am putting hardwood floors in the house and remodeling the kitchen so time is sparse but knew you all would like to see this along with a picture of the car its going into(the black turbo)
Ben
89 944,85.5 944
914-6werkshop.com
Old 10-08-2007, 06:51 AM
abit off center
cgarr's Avatar
You have some nice cars there Ben!
______________________
Craig
G2Performance
Old 10-08-2007, 07:01 AM
