3.5 Litre Engine
I am looking to build a 3.5 liter naturally aspirated motor for my 911, can anyone advise the route they took to build a similar engine, pistons and barrels ( make, MAHLE, KS , other?) what sort of induction system, custom manifolds, modified 3.2, or others?
Anny watch outs? Any advise on exhaust systems and cams? Thanks |
Hi Mark
I have recently finished the build of a 3.5 l 911 motor. The build specs are as follows: 3.2 carrera base motor 964 cylinders - reconditiond 100 mm JE pistons - high compression GT3 oil pump & 964 piston squirters Twin spark & midified cylinder heads Equal length exhaust ITB - custom with long induction length Sequential injection & ignition Everything balanced & lightened where possible This has turned out to quite an interesting build. A few minor problems encountered with the 964 cylinders, and not the more expensive 100mm non 964 cylinders. But this is still dooable, with a bit of creativity. PM me for the details if you want. Please remember that this was almost a money is no object build, with ultimate performance in mind. I will be opening the motor after every 30 to 50 hours. Good luck. |
I was under the impression that the head stud spacing was different for 964 cylinders vs. a 3.2 case?
What machine work is neccessary to run these?
Earlysport _____________________________________ 69 911E, 69 911E RS Rep 3.0L Hotrod, 77 930 IROC REP 3.6L SOLD, 968CS SOLD, 987 Boxster S SOLD |
search for Carrera3.5L as a user here. Ralph built a well-publicised motor as you describe 3 or so years ago.
Ed Hughes 2015 981 Cayman GTS 6 speed,Racing Yellow Past:1984 911 Targa (Ruby), 1995 993C2 (Sapphire), 1991 928S4 |
The most difficult part of the build was machining the cylinders to suite the 3.2 stud spacing, as well are the O ring groove in the base of the 964 cylinders, and making clearance for the case through bolts, that will interfere with the 964 cylinders.
I would recommend either Nickies made to suite, or locate the Mahle cylinders that were made with the 105mm spigot, and 100mm bore, but on the 3.2 stud spacing. |
Your ultimate goal with the motor will be key to any recommendations. Is this motor going to be primarily used on the street, track, a mix of both? Any emissions regulations to consider?
Here's my experience: I thought this would be a 99% street motor and it was built as such. I now use it mostly on the track, with some light street driving. I simply underestimated my Porsche addiction and the alure of track days. 3.0 case Early 3.0 heads (larger intake and exhaust ports) 3.2/3.3 crank and rods ARP rod bolts and head studs GT3 oil pump Mahle 100mm cylinders Mahle 100mm DME pistons (9.8:1 compression) 964 cams Twin plugged (964 distributor converted for mechanical advance) Two 6-pin CDI boxes and stock coils 993 heat exchangers Triad muffler The motor originally had early CIS, but it just didn't breathe enough. I switched to 46mm PMOs and the engine came to life. The car is very streetable and performs well on the track, but I left alot on the table by not going with a hotter cam. I looked into making the change to a mod-S cam, but with the motronic pistons I'll have clearance problems. The engine has gobs of torque, pulls like mad, and the throttle response with the carbs is simply amazing. If I were to do things all over again I would go with carbureted pistons and a hotter cam, but that's about it. I suppose I could have done better by starting with a 3.2 instead of a 3.0, but it's all academic at this point. Best of luck with your project! |
Mark:
Jon's input on his 3.5 motor is excellent and such a setup makes a great street engine. You did not say anything about how your 3.5 would be used so its difficult to offer specific suggestions,.... ![]() Jon's build is well done and the only thing I would offer is that if such a combination is going to see much track use, I would strongly recommend either Pauter or Carrillo rods and having the crank cross-drilled with the modified center main bearings for better oiling. Of course, camshaft choices are based on the application.
Steve Weiner Rennsport Systems Portland Oregon (503) 244-0990 porsche@rennsportsystems.com www.rennsportsystems.com |
MBruns for President
I think he has one of the ultimate 3.5 engines. and Jeff Alton has one of the better 3.4 engines - 3.4 build part 2!
Current Whip: - 2003 996 Twin Turbo - 39K miles - Lapis Blue/Grey Past: 1974 IROC (3.6) , 1987 Cabriolet (3.4) , 1990 C2 Targa, 1989 S2 |
Thanks Jeremy, mine is pretty, but let me get it tuned before we put it into the "one of the better" categories..
Yours aint to shabby either!Cheers
Turn3 Autosport- Full Service and Race Prep www.turn3autosport.com 997 S 4.0, Cayman S 3.8, Cayenne Turbo, Macan Turbo, 69 911, Mini R53 JCW , RADICAL SR3 |
Thanks for the input and links to previous threads. To answer some of the questions- I am going to be using mainly on the street, and am looking for around 300 HP, but with a snappy throttle response.
I have access to both 3 liter and 3.2 litre engine casings and heads, and the condition of these will determine the base for the exact specification of the end motor. |
Well, my limited experience with the ITB's suggest they are the ticket for the snappy throttle response you are after.
Cheers
Jeff,
Can you give me some information on ITB's- they are not that common in our neck of the woods! Thanks |
Mark,
The ITB's have one throttle for each cylinder. Search my name and "build" and you will see my threads with pics of my instalation. Running such system requires an aftermarket ECU, of which many are available. I went with a Microtech (know more for rotaries than porsches, but a master tuner is about 1 mile from here...) I am using 48mm Jenvey throttles on my motor with custom linkage and custom port matched manifolds. However I am doing some Beta testing shortly on a new set up and may be selling the Jenveys. Other places to look for ITB's include TWM. http://www.twminduction.com/ http://www.jenvey.co.uk/ Cheers
Those are the ones I will be testing......
![]() Cheers
Thanks, the way to go!
user & abuser
hey
been busy.... but i also have a 3.5L mines based on the 3.3L 930 case, which isn't different from your options. i used the 74mm crank with 100mm Mahle P&C's. mod-s cam 46mm webers etc....etc... made 278rwhp with B&B headers.... it feels similar but with mroe mid range with georges european racing headers. is a great engine no matter what i think. Bigger discplacement, and it realllllllyyyy revs fast...magnified by the low gear ratio in my 915.... keep us updated.
vini vidi vici |
