3.6 head studs
i put a magnet to my studs and nothing. that means dilivar, right?
they are all in good shape. should i replace them with steel ones or just leave them alone? |
Try not, Do or Do not
Replace them with the best, Supertec head studs.
They are available from our host PP.
Henry Schmidt SUPERTEC PERFORMANCE Ph: 760-728-3062 Email: supertec1@earthlink.net |
The 993 dilivar studs seem to hold up better than the old ones. If they look good with no corrosion I'd use them. You don't say what kind of engine you have but if it's an aluminum case then steel studs are also a good choice. If it's a mag case then those dilivar studs are the only ones I'd use.
-Andy
72 Carrera RS replica, Spec 911 racer |
My 1992 3.6l's head studs are magnetic.
1981 911sc RoW Coupe (forever under 3.6L conversion) 2003 996TT Basalt black |
sorry, it's a 90 C2.
they look just fine to me. are the 993 studs different than the 964 studs? i'll check out the supertec ones. i saw some ARPs too. are they any good? |
take a look:
the flash actually makes them look much more beat up than they really do
Those are not 993 studs, 993 studs are threaded the whole length. They look like the replacement Dilivar studs that have been sold over the last 20 years or so. I would use either new 993 dilivar studs or any steel studs such as factory, ARP, Supertec, etc. The studs you have may be better than the original dilivar studs but unless you had a Mag case engine I wouldn't take a chance on them.
-Andy
and so the parts list continues to grow.
thanks for the input |
Hmmm,
I have a set of stock 3.6 studs I pulled froma 90 motor here, I will put a magnet on them this week and see.......... Cheers
Turn3 Autosport- Full Service and Race Prep www.turn3autosport.com 997 S 4.0, Cayman S 3.8, Cayenne Turbo, Macan Turbo, 69 911, Mini R53 JCW , RADICAL SR3 |
