drola's Avatar
3.6 head studs
i put a magnet to my studs and nothing. that means dilivar, right?
they are all in good shape.
should i replace them with steel ones or just leave them alone?
Old 11-18-2007, 03:13 PM
Try not, Do or Do not
Henry Schmidt's Avatar
Replace them with the best, Supertec head studs.
They are available from our host PP.
Henry Schmidt
SUPERTEC PERFORMANCE
Ph: 760-728-3062
Email: supertec1@earthlink.net
Old 11-18-2007, 04:18 PM
The 993 dilivar studs seem to hold up better than the old ones. If they look good with no corrosion I'd use them. You don't say what kind of engine you have but if it's an aluminum case then steel studs are also a good choice. If it's a mag case then those dilivar studs are the only ones I'd use.
-Andy
Old 11-18-2007, 05:01 PM
My 1992 3.6l's head studs are magnetic.
1981 911sc RoW Coupe (forever under 3.6L conversion)
2003 996TT Basalt black
Old 11-18-2007, 05:09 PM
drola's Avatar
sorry, it's a 90 C2.
they look just fine to me. are the 993 studs different than the 964 studs?
i'll check out the supertec ones. i saw some ARPs too. are they any good?
Old 11-18-2007, 05:35 PM
drola's Avatar
take a look:
Old 11-18-2007, 05:38 PM
drola's Avatar
the flash actually makes them look much more beat up than they really do
Old 11-18-2007, 05:42 PM
Those are not 993 studs, 993 studs are threaded the whole length. They look like the replacement Dilivar studs that have been sold over the last 20 years or so. I would use either new 993 dilivar studs or any steel studs such as factory, ARP, Supertec, etc. The studs you have may be better than the original dilivar studs but unless you had a Mag case engine I wouldn't take a chance on them.
-Andy
Old 11-18-2007, 07:12 PM
drola's Avatar
and so the parts list continues to grow.
thanks for the input
Old 11-18-2007, 08:12 PM
Jeff Alton's Avatar
Hmmm,
I have a set of stock 3.6 studs I pulled froma 90 motor here, I will put a magnet on them this week and see..........
Cheers
www.turn3autosport.com
Old 11-18-2007, 11:15 PM
