GotaT's Avatar
Send a message via AIM to GotaT Send a message via Yahoo to GotaT
Crankcase Vent , Necessary?
I have a 2.4 and was wondering if the OE rubber line coming from the Oil tank to the Back of the Factory Air Box is Necessary.. Im going to be putting K'N filters which wont allow for that hose. Is it ok for me to just Plug the HOLE on the Oil tank?
This will still leave one hose remaining .. from the Oil tank to the crankcase vent cover...
Old 10-25-2007, 08:23 PM
BURN-BROS's Avatar
You will still need to vent the tank. Use a small "overflow" tank with a small K&N type of air filter.
Aaron. F.S. 1965 Solex engine w carbs/cleaner
Burnham Performance
https://www.instagram.com/burnhamperformance/
Old 10-25-2007, 09:17 PM
GotaT's Avatar
What kind of tank do you mean? Why is it necessary?
Anyone who has K/N filters have a photo of what they've done?
Old 10-26-2007, 08:40 AM
1972_911T's Avatar
Below is a picture of an engine supertec built, this was posted on another thread by henry schmidt it shows a similar thing described above where the oil breather is attached to a small tank that drains back to the crank case. I belive the part used is from a later 90's porsche henry may chime in with more details.
1972 911t RS Styled
G50 conversion underway
1972t Resto Project - http://www.ddk-online.com/phpBB2/viewtopic.php?t=16695
Old 10-26-2007, 03:08 PM
Komenda Fan's Avatar
Just use a thing of skippy...
2012 911 Black Edition Cabriolet
2008 Cayman S Grey on Black - flooded, written off
1977 930 Turbo Carrera Black on Red #411
1987 951 Black on Black - sold to make room for the 930
1972 911 2.7 - I regret selling her every single day....
Old 10-26-2007, 04:12 PM
Jeff Alton's Avatar
Here is mine..............
cheers
www.turn3autosport.com
Old 10-26-2007, 09:17 PM
304065's Avatar
Jeff, where did you plumb in the oil return line? It seems to me that the vent line produces significant oil vapor from the tank, even though the tank itself is intended to act as an air/oil separator with a headspace above the oil level. I would expect that oil would condense in the vent and need to go somewhere, although Porsche's solution, at least on my '66 and '71, was to run the vapor to the air cleaner and then vent the liquid oil from the air cleaner overboard to that funny cylindrical thing with the rubber cap on the engine!
'66 911 #304065 Irischgruen
‘96 993 Carrera 2 Polarsilber
'81 R65
Ex-'88 Carrera (Sold 3/29/02)
Old 10-27-2007, 04:09 AM
GotaT's Avatar
Komenda Fan.. Did you just Plug yours up? I still dont really see why it is Necessary.... but If I have to use something.. Whats the Least expensive Best looking thing I can do?
Old 10-27-2007, 07:03 AM
You want cheep?
Howz'a bout a mixed nuts container from Costco.
An AX will put 8 oz of oil in there. .......
JPIII
Early Boxster
Old 10-27-2007, 07:29 AM
BURN-BROS's Avatar
Your engine needs to be vented to atmosphere. If you plug the tank you will have positive case pressure at moderate to high rpms. Seals/gaskets start to blow out and the scavange side of the oil pump can cavitate.
Burnham Performance
Old 10-27-2007, 09:04 AM
Jeff Alton's Avatar
John, the comming out the bottom is now a clear tube that runs verticaly back up the side of the tank. This way it can show me the how much oil is in can. So far, after only 350 miles, there is no oil in the can....
Cheers
Old 10-27-2007, 09:19 AM
GotaT, it might be hard to see, but mine runs to behind the 72 oil filter assembly and then back out to the skippy. I love it, because its light weight and easy to check visually. Plus, since my car was repainted ten years ago from Viper Green to Silverish, the lid is my only real link to Viper Green! Well, that and a few paint chips...
Old 10-27-2007, 10:04 AM
GotaT's Avatar
So Basically, All I really need is a Hose coming out of the tank with a Filter of Any sort and a Tank to catch Any Oil that the Filter would not.... Right?
There must be some sort of Generic Breather/Filter that could be fitted in an Discrete Place..
Old 10-28-2007, 08:07 AM
i used a section of washing machine discharge line from Home Depot and the K&N breather. The stock hose bends are perfect. The engine is tight so no noticable fumes and no oil fume discharge layer in compartment. The high angle returns oil droplets. It may not be track legal in some areas of the US.
Ronin LB
'77 911s 2.7
PMO E 8.5
SSI Monty
MSD JPI
w x6
Old 11-01-2007, 12:45 PM
GotaT's Avatar
See,.. now Thats what Im talkin' about!.. thats exactly what I was thinking of!... Thanks for all the posts! .. Cant wait to get my car back on the road w/ my Custom Ground Cams!...
Later
Old 11-01-2007, 04:22 PM
you still need the hose from engine to tank.
Ronin LB
'77 911s 2.7
PMO E 8.5
SSI Monty
MSD JPI
w x6
Old 11-01-2007, 05:06 PM
