Racer
preston_brown's Avatar
Damaged half a main bearing shell
OK, stupid mistake.
I am assembling my bottom end. I was rotating the crank with the oil pump to check backlash and then to make sure everything was smooth before mating the case halves. One of the bearing shells (#7) beneath the crank turned also, and I didn't notice.
I placed the case halves together and started tapping them together. I was using a rubber mallet and they just weren't seating well on the nose end. I gave up, pulled the halves apart to check what was going on, and saw the mistake -- the two bearing halves for #7 were slightly overlapping.
The bearing seat in the case looks OK. The bearing shell itself got slightly crushed, but definitely deformed, and I can feel the damage with my finger. I definitely need to replace these bearings. Crap, and I was going to try and get a lot done on the motor this weekend.
Does anyone have a loose std/std. pair of main bearing shells for a '87 Carrera that they could sell me by themselves? Beats having to pay $200 for an entire set of new mains, and Pelican lists the part (930.101.132.15) as "special order only.
After feeling mad and stupid for awhile, I then got to enjoy the task of cleaning all the 1194 and loctite off the case half again.
Preston Brown
Street: 2009 911 Carrera S Coupe | 2015 Cayenne S | 1995 Audi ÜrS6 (unicorn)
1965 356 C Coupe | 2010 F250 (support vehicle)
Race: 1994 964 GT2/1 | Various 944s | 2016 Superlite SLC | 2007 997 Carrera
Old 11-02-2007, 07:37 PM
If you have an old bearing from when you took the engine apart you could use it. The other option would be to try to just buy one new bearing. Some racers use the old bearings on pupose to have a little more clearance for less drag and more HP.
-Andy
Old 11-03-2007, 07:13 PM
Loose nut bhind the wheel
If the 2.7 bearings are the same I have them and I am 6 miles from you. i will check the part #.
Ed
1970 911S Targa 2.7RS MFI dual plug 10.5:1
1974 260Z SCCA ITS
1998 M3
Old 11-04-2007, 07:01 PM
Try not, Do or Do not
Henry Schmidt's Avatar
CALL ME, WE HAVE SOME.
Cheers
Henry Schmidt
SUPERTEC PERFORMANCE
Ph: 760-728-3062
Email: supertec1@earthlink.net
Old 11-05-2007, 06:24 AM
Racer
Crap, too late, I ordered a full set Monday morning.
Anyone need most of a set of 911 main bearings?
Preston Brown
Old 11-07-2007, 04:53 PM
