Schleprock
A bit of advice on adjusting your valves when you get the cams and rockers installed........... Set the clearance and then rotate the engine, check/adjust again and check adjust again. Reason being, when you goop up the cam and rocker pad with assembly lube, it can affect your valve clearances very easily. As you rotate the engine, the rocker will wipe off the lube as it's bearing on the cam lobe and the clearance opens up.
My engine was quite noisy when I first fired it up and broke it in. The valves were VERY loose. But don't get me wrong, i'm a notorioulsy sucky valve adjuster. So maybe i'm being too concerned about my perceived thing to watch out for.
Kevin L '86 Carrera "Larry" |
Ed Hughes 2015 981 Cayman GTS 6 speed,Racing Yellow Past:1984 911 Targa (Ruby), 1995 993C2 (Sapphire), 1991 928S4 |
abides.
Thanks so much,
Graham 1984 Carrera Targa |
He just called it ceramic coating. My fan and shroud were done this way. The place is Specialized Performance Coatings in Arlington, TX. Michael Tomlinson is the owner. 817-274-1947
abides.
Thanks. I wanted to powdercoat my fan and housing, but I've had people tell me that even powdercoating won't resist chipping. This sounds like it could be the end-all of fan coatings for me.
Ed, I'm scared... I don't have valve spring tools, or crow foot whatevers, or piston ring compressors - should I just let a professional handle my 3.0 rebuild ?
James Shoffit 78 911 SC Track Car 83 911 SC garage queen (someday daily driver?) 05 Honda Civic 07 Expedition Eddie Bauer EL |
I've already loaned out my stand and yoke, but other than that, it was all tools on hand except for the cam holder which I just shipped back to a buddy I borrowed it from. You can get the cam nuts off (should be able to) with an impact wrench for tear down, so you won't need the holder until cam timing time. Maybe Rick Randall has one locally? My heads were shipped complete to Ollie's in Calif for rebuild, so I didn't disassemble them. Let me know if you need the goodies.
Ed, got them today, thanks!!
The SC cam uses a different tool, but I can ship my spare "Z" block back if James needs it. cheers
Turn3 Autosport- Full Service and Race Prep www.turn3autosport.com 997 S 4.0, Cayman S 3.8, Cayenne Turbo, Macan Turbo, 69 911, Mini R53 JCW , RADICAL SR3 |
Ed, great job....we are gearing up to rebuild a 3.2 here. Maybe I missed it... how did you get the case/etc. so clean? Thanks.
Normally this time of year I am planning my week in Whistler, where we fly into YVR and drive up. But not this year - wife wants to go to Paris, so there you have that. If we do go to Whistler, it will be fall of 08.I am pretty sure I can get any tools I need locally. Rick Randall has nearly everything, I think, and he doesn't live that far from me. My main need is the stand and yoke, which I am probably going to split with another guy here that does his own SC engines. I don't mind paying for it, I just don't want to store it. I have a tiny 2 car garage, and 2 SCs in it, so no extra room (but a full garage is a happy garage).Ok, you guys have bolstered my spirits... I'll grab the camera and head down to the garage soon
The case did get hot tanked before inspection, but it had several hours of me scrubbing as well. I don't know how many cans of brake cleaner I went thru, literally 40 I bet...
