1972_911T's Avatar
Head Stud Troubles
Im in the process of fitting my aftermarket head stud kit and I seem to be having trouble getting the thread lock to harden. Ive left them overnight then tested them to make sure they have stuck and only 1 out of the 8 I have just tried stood up to a resonable amount of force most of them undo like there in nothing on them. Where can I be going wrong?
BTW im using blue permatec stud lock that came with the kit.
1972 911t RS Styled
G50 conversion underway
1972t Resto Project - http://www.ddk-online.com/phpBB2/viewtopic.php?t=16695
Old 12-28-2007, 11:48 AM
did you degrease the threaded holes with brake-kleen and blow them dry?
206 637 4071
Old 12-28-2007, 01:57 PM
1972_911T's Avatar
Hi John yes I degreased them with paint thinners. Can the temp affect the thread lock?
1972 911t RS Styled
Old 12-28-2007, 02:58 PM
Paint thinner doesn't evaporate very well. I prefere Acetone or Laquer thinner. There are also primer products for Locktite (they smell like Acetone).
-Andy
Old 12-28-2007, 08:55 PM
Banned
If you used any oil based paint thinner (like mineral spirits) to clean your stud bosses then that is your problem . . . as per the previous reply, you must use a cleaner that leaves no residue. The air temp should not affect the thread locker in the manner you describe . . .
Ronnie
Old 12-29-2007, 08:06 AM
Stranger on the Internet
patkeefe's Avatar
I would concur with eagledriver and JW. I use either acetone or methyl ethyl ketone for prep cleaning. Also, blue Loctite is not the end-all. The special red stuff is the cats a$$.
Pat
Patrick E. Keefe
78 SC
Old 12-29-2007, 08:16 AM
HawgRyder's Avatar
Send a message via ICQ to HawgRyder
I would have suggested the Loctite green to be used for studs.
609 I think is the number....permanent...needs heat to take them out.
Bob
Bob Hutson
Old 12-29-2007, 10:25 AM
1972_911T's Avatar
I used automotive cellulose paint thinner which is solvent not oil based. I will get some acetone from work and re-do them with red locktite.
1972 911t RS Styled
Old 12-30-2007, 01:59 AM
If they are not a tight fit that could cause trouble. Loctite thread lock is anerobic meaning it cures in the absence of air. You will notice that it does not cure when left on an open surface.
Art
'75 911 US Carrera #390
'74 MGB, AH 3000 BN7 V8,
'65 Mustang Fastback, 66 bronco U13
Old 12-31-2007, 04:34 PM
