Banned
Rebuilding
Rebuilding porsche 911 engine , rod bearing clearance sitting nice at .002
Old 07-18-2024, 01:56 PM
Solid first post.
1975 911 3.4 outlaw/hotrod? lsd
1988 535i
1987 535is
1973 bronco ranger
Old 07-18-2024, 01:58 PM
Try not, Do or Do not
Henry Schmidt's Avatar
I'm not sure what we're looking at. Is the second picture the engine being assembled?
Generally speaking, it is not a good idea to reuse old Dilivar studs or to use a mismatch upper and lower stud combination.
Henry Schmidt
SUPERTEC PERFORMANCE
Ph: 760-728-3062
Email: supertec1@earthlink.net
Old 07-19-2024, 09:52 AM
Banned
Old 07-19-2024, 02:07 PM
I had a though about my earlier post. My comment about head studs was based simply on the pictures you posted. The lower studs look like coated Dilivar. It is possible that some previous builder replaced the Dilivar with Canyon "Super Suds".
They are a coated steel stud designed as a Dilivar replacement. If you test them with a magnet you'll know. If the are magnetic, you're go to go.
Just a thought.
Henry Schmidt
Ph: 760-728-3062
Old 07-20-2024, 06:36 AM
