Less brakes, more gas!
Differences in diameter groups of pistons and cyls???
Andy's comments from this thread: Piston Gap Measurement
![]() ![]() Please don't tell me I have to tear it down again NOTE: I have a set of Henry's trick 906 replica air deflectors at the coater. I can put these in after the heads are on unlike the regular ones.Best regards, Michael
Michael ![]() '82 Euro SC 'Track Rat' 22/29 Hollows, 22/22 Tarrets, Full ERPB F/R, Rennline Tri Brace, Glass bumpers, Pro 2000's, 5 pts, blah blah blah '13 Cayenne GTS Last edited by euro911sc; 01-23-2008 at 06:33 PM.. |
Irrationally exuberant
Pistons and Cylinder come in 2 cylinder height groups (as you know) and 4 diameter groups.
-Chris
'80 911 Nogaro blue Phoenix! '07 BMW 328i 245K miles! http://members.rennlist.org/messinwith911s/ |
If you look in a spec. book or the Haynes manual you will see the groups. They are marked 0,1,2, and 3. I can't recall exactly where the marks are but I think the piston marks are stamped in the face. Someone might help you with where to find the marks.
You can assume that the pistons you originally had were all the same size. Once you find the marks on the cylinders you will know if you have a problem. Maybe whoever sold you the one piston can tell you what group it was. Sorry to make you worry. -Andy
72 Carrera RS replica, Spec 911 racer |
Crap... I guess I have to rip it apart again and make sure it all matches up
I'll have to order more 574 as I've pretty much run out... Or can I simply remove the heads and cam carriers as one unit?Best regards, Michael
Michael ![]() '82 Euro SC 'Track Rat' 22/29 Hollows, 22/22 Tarrets, Full ERPB F/R, Rennline Tri Brace, Glass bumpers, Pro 2000's, 5 pts, blah blah blah '13 Cayenne GTS |
YEAH! All I have are '+'s on the top of my pistons... What luck! It is hard to see, but at full resolution it is apparent. But, what group is that? It is not the weight group as they are all '++' marked on the inside of the piston and I matched that correctly...
![]() (I'm soooo happy I took lots of pictures!) Just checked the engine... looks like I'm in mismatch. #1 & #2 cyls show a '0' stamped in the same place the height group is stamped (logically the place to put the diameter group stamp). #4-#6 show a '1'. If I were a betting man I would now say I have two in group 0 and four in group 1 with all the pistons being in the same group. I can assume that since I had 5 pistons and 4 cyls from the original engine that '+' means group 1 for the pistons as that would match my group 1 cyls. Here, it looks like, I have two pistons from group 1 put into 2 cyls of group 0. The specs on pistons do overlap for the two groups while the specs for the cyls do not. Now... what are the consequences of getting mismatched like this? Closer piston to cyl wall than designed means what? Best regards, Michael PS I can't imagine the pain of trying to make a complete matching set from a box of singles...
To make sure you have a good set of matching pistons and cylinders it is best to do the following:
1. Weigh all the pistons with their wrist pins and make sure the spread in weight (heaviest-lightest) is less than 8 grams 2. Measure the top ring clearance on each piston to make sure the it is within spec 3. Measure the piston diameters with a micrometer across the skirt, below the wrist pin 4. Measure each cylinder bore diameter with a dial bore gage in (4) places (top and bottom of stroke at 90 deg orientation). 5. Make sure the piston to cylinder clearance (cylinder diameter-piston diameter) is below 0.004" If you meet all these criteria, you've got a good set.
Tom Butler 1973 RSR Clone 1970 911E - Sold but Never Forgotten 914-6 GT Clone |
I actually measure the clearance directly with a feeler guage. If you take the rings off you can slide the pistons into the cylinders and slip a feeler blade between the skirt and the cylinder wall. The min clearance is toward the bottom of the cylinder. You need the blade in at least .5 inches or so to get a good feel. So push the piston down from the top over the feeler blade and see how hard it is to move. When it can just slip from gravity and doesn't rattle around I call that blade size the clearance.
Minimum safe clearance is .0015 inches. Wear limit is .004 inches. I like to have about .002 to .0025 if I can get it. I had a mismatched set last time I rebuilt and by measuring all the pistons in all the cylinders I was able average out the clearances. In other words match the largest piston with the largest cylinder and on down the line. With your sets being close I bet you can match them up enough to be fine. -Andy
Andy and others,
Since I have put the cam carriers on already can I simply unbolt the heads from the head studs, measure, and re-assemble in the same order if all is well? I assume, if I must swap cylinders around to get good clearance on all 6, I should strip the cam carriers off, clean them, and start over. Best regards, Michael
Ok, I checked the clearances. 0.0030, 0.0025, 0.0025 for #'s 1, 2, & 3... so all is good.
To check I simply took the heads and cam carriers off as a unit. Everything will go back together the same way so can I simply remount the head/cam carrier as a unit without unbolting the heads and re-sealing the head cam carrier surface? Best regards, Michael
Hey Michael... it sounds like you may be out of the woods on this one! I hope the best for you here.
Can you post a pic of Henry's trick 906 replica air deflectors? I did'nt know such existed and how actually do they differ from the stock ones? Thanks for your help here and best of luck finishing the build with zero issues!! Bob
I live for 911 tweaks... |
Michael:
The engine looks great! All your hard work is going to pay off. Even this rework that you are doing will pay dividends. Best of all, it beats the alternative, huh? Don't want to go down that nasty road again for sure. Cheap insurance as far as I am concerned, better safe than sorry. Good luck!
Ed Paquette 1983 911SC 1987 944S 1987 944 Manual (Donated to the Nat. Kidney Foundation) 1987 944 Automatic (Recently sold to another Pelican) |
Yes you can put it back together without removing the heads from the cam carriers. It makes it much easier. It's best to use new CE rings but I've re-used the old with success when I was too impatient to get new ones.
-Andy
All back in black and on to the next step
Cam turns nice and smooth!![]() Lots of cleaning to do today but, with luck, I'll be timing this evening or tomorrow.![]() Thanks all! Michael
