Help identifying engine
Trying to identify an engine, engine number is 6378840 - what is it? Could someone explain what the numbers stand for please. Also is it originally from a car with this chassis: 911531xxxx
Here's a pic of it:
Old 01-29-2008, 10:47 AM
azporsche911.com
Hoffmanmotors's Avatar
hope someone will chime in for you and tell you if its ROW or US but just from looking at it i see a red fan shroud, CIS, metal fuel lines so im guessing a 80-83 3.0 SC engine.
Jeff Hoffman (Son)
Tom Hoffman (Father)
79 911sc ROW guards red coupe
father son project.
Old 01-29-2008, 11:34 AM
MBEngineering's Avatar
HI Monkeydub
have a look in hear, I may help???
Newbie Internal Engine Designation Code Question
regards mike
Regards mike
1983 911 SC sport, 1982 mini city
Old 01-29-2008, 12:50 PM
HI Monkeydub.
you will need the engine type No' it is just behind the engine No' and should start with 930/xx, the engine No' looks like a 1977 engine?? with the wrong/late injection on it.
have a look on hear also;
posted for educational purposes only,
regards mike
Regards mike
Old 01-29-2008, 01:08 PM
Hi Mike....sorry haven't called. Been incredibly busy. Will call ASAP about inspecting the car. Thanks for the info. Will try and get the other number.
Old 01-29-2008, 01:17 PM
HI Monkeydub
from the engine No' you have there it looks like a 2.7 engine , you will have to get the type No' to confirm which engine it has. I have been talking to Bert about the car and he has info on it and has been to look at it some time ago, I can give you his No' if you like and he is in the area this week.
regards mike
Regards mike
Old 01-29-2008, 01:40 PM
That would be great. This topic was about another 911 i'd found. I'll call you tomorrow for the number.
Thanks, Rory
Old 01-29-2008, 02:59 PM
The engine number is 930/10
Old 01-30-2008, 08:08 AM
HI Monkeydub
look on the link, as it is a 81 SC engine??
regards mike
Regards mike
Old 01-30-2008, 09:33 AM
HI again, the engine No' should read 631 8840?? would you check that the "7" is actually a "1" and then it will tie up OK as a 1981 engine, and not this,
"6378840"
regards mike
Regards mike
Old 01-30-2008, 09:40 AM
