How can you tell which rod is which? HELP
I have a few sets of rods that I aquired recently. From what I understand the # on the beam does not determine the application. If not then how do you tell?
Here are 2 of the beam #'s im trying to identify. 911.103.103.0r 911.103.105.0r Can anyone offer some input? Kurt ![]() ![]()
Never drive faster than your gaurdian angel can fly. 82 SC w/965S eng and G50 6:1 hp/w ratio 72 911t 2.6 twin plug and 72' 911t 57k orig 1 own miles 65/66 912 1 owner 76k orig 01' Aston Martin DB7 V12 Vantage Coupe 6spd |
Kurt,
OK, we know they are at least 2,2 rods, you can tell that by the 911 part number, as opposed to 2,0 rods which say 901. Best way is to measure the center-to-center distance with a caliper. You measure between the bottom of the little end and the top of the big end, then measure big and little and subtract half of both distances to get the center-to center length. That will tell you whether they are 2,4-2,7 rods or 3.0 or later. . . . To tell 2,2 from 2,4 and later you can also measure the big end journal width, it's wider in the later cars. When the reduced the bearing journal diameter to stroke the crank they made it wider to maintain the same area.
'66 911 #304065 Irischgruen ‘96 993 Carrera 2 Polarsilber '81 R65 Ex-'71 911 PCA C-Stock Club Racer #806 (Sold 5/15/13) Ex-'88 Carrera (Sold 3/29/02) Ex-'91 Carrera 2 Cabriolet (Sold 8/20/04) Ex-'89 944 Turbo S (Sold 8/21/20) |
Is there a chart that shows the lengths? Also the first rod (part of a set) appears to be black in color rather than the raw steel look of the others. Does that signify anything?
Kurt
Kurt
911.103.103.0R = 2.2 rods (66mm crank) 911.103.105.0R = 2.4/2.7 rods (70.4mm crank)
Tom Butler 1973 RSR Clone 1970 911E - Sold but Never Forgotten 914-6 GT Clone |
Yessir,..thats a nitrided "S" rod.
Steve Weiner Rennsport Systems Portland Oregon (503) 244-0990 porsche@rennsportsystems.com www.rennsportsystems.com |
