pjv911's Avatar
Send a message via AIM to pjv911
How can you tell which rod is which? HELP
I have a few sets of rods that I aquired recently. From what I understand the # on the beam does not determine the application. If not then how do you tell?
Here are 2 of the beam #'s im trying to identify.
911.103.103.0r
911.103.105.0r
Can anyone offer some input?
Kurt
Never drive faster than your gaurdian angel can fly.
82 SC w/965S eng and G50 6:1 hp/w ratio
72 911t 2.6 twin plug and 72' 911t 57k orig 1 own miles
65/66 912 1 owner 76k orig
01' Aston Martin DB7 V12 Vantage Coupe 6spd
Old 02-03-2008, 01:21 PM
304065's Avatar
Kurt,
OK, we know they are at least 2,2 rods, you can tell that by the 911 part number, as opposed to 2,0 rods which say 901.
Best way is to measure the center-to-center distance with a caliper. You measure between the bottom of the little end and the top of the big end, then measure big and little and subtract half of both distances to get the center-to center length. That will tell you whether they are 2,4-2,7 rods or 3.0 or later. . . .
To tell 2,2 from 2,4 and later you can also measure the big end journal width, it's wider in the later cars. When the reduced the bearing journal diameter to stroke the crank they made it wider to maintain the same area.
'66 911 #304065 Irischgruen
‘96 993 Carrera 2 Polarsilber
'81 R65
Ex-'88 Carrera (Sold 3/29/02)
Old 02-03-2008, 01:24 PM
pjv911's Avatar
Is there a chart that shows the lengths? Also the first rod (part of a set) appears to be black in color rather than the raw steel look of the others. Does that signify anything?
Kurt
Old 02-03-2008, 01:31 PM
Kurt
911.103.103.0R = 2.2 rods (66mm crank)
911.103.105.0R = 2.4/2.7 rods (70.4mm crank)
Tom Butler
1973 RSR Clone
1970 911E - Sold but Never Forgotten
914-6 GT Clone
Old 02-03-2008, 03:42 PM
Kurt
Yessir,..thats a nitrided "S" rod.
Steve Weiner
Rennsport Systems
Portland Oregon
(503) 244-0990
porsche@rennsportsystems.com
www.rennsportsystems.com
Old 02-03-2008, 08:50 PM
