ahead of the curve
Jeff Burger's Avatar
how to get 3.6 crank pulley off?
I tried to search and couldn't find anything so maybe someone can help - Started using a three prong puller to remove the crank three pulley on a 92 3.6 . it started to bend the pulley so I stopped It looks like the outer pulley has some threads that you ,might drive a bolt or special tool into the crank and drive it off? anyone got any hints on how to get the pulley off. Also how about a good source for a single pulley - thanks jeff
Old 05-30-2004, 02:57 PM
Author of "101 Projects"
Wayne 962's Avatar
Hmm, off the top of my head, I think it's similar to the early cars. There's a bolt (same bolt according to the parts diagrams) in the center that affixes the pulley to the shaft. There's a small woodruff key (this is different) that holds it in place. Maybe your woodruff key is getting cocked?
-Wayne
Old 05-30-2004, 06:38 PM
they don't come off without this tool. the pulley hub is a taper fit over the crank snout. the dealer sells it fairly cheap, or make one.
thread is 16X1.50, from bottom of hex head to bottom of thread- 20mm, shaft is 12mm wide, 35mm long. find a 16X55X1.50 bolt and turn or grind down the end.
206 637 4071
Old 05-31-2004, 02:12 PM
ahead of the curve
Aha! thank you for taking the time to provide the picture and detailed measurements. I saw the threads in the outer pulley and was thinking there might be something like that but didnt want to risk damaging the crank snout - thanks John
Jeff burger
19 Carrera T - MPS member
92 C2 SR coupe M491/ 3.8 look- manual
92 C2 SR coupe cobolt blue- manual
73 914 1.7 (?) AG -a solid project looking 4 a sugar daddy
73.5 T gemini blue SR coupe sold 8/22 my last long hood gone
Old 06-01-2004, 04:40 AM
Irrationally exuberant
ChrisBennet's Avatar
Porsche tool 9285/1
'80 911 Nogaro blue Phoenix!
'07 BMW 328i 245K miles!
Old 06-01-2004, 06:36 AM
MPDano's Avatar
Originally Posted by ChrisBennet View Post
Porsche tool 9285/1
I can't seem to find this part using the part search tool. Can you provide a direct link?
1981 Porsche 928 "Euro" Auto Gunsmoke Metallic Flat - Black Interior
1983 Porsche 928S "US" Auto Light Bronze (Copper) Metallic - Brown Interior **SOLD**
Old 01-12-2008, 01:10 PM
I can't find it listed either but since it's a Porsche tool, call Pelican.
I got a deal on mine a few years ago, someone borrowed it and it broke. They replaced it but I think it was quite expensive (~$75).
I think a fully threaded M16x1.5 bolt may be hard to come by. My local metric fastener shop (BelMetric) didn't have one when I checked a year or two ago. I just tried searching MSC and McMasterCarr: MSC doesn't seem to carry M16 at all and McMasterCarr only has the socket headed type.
-Chris
Old 02-03-2008, 05:57 AM
Check out the specs on a homemade tool.
Removing 964 Crank Pulley...
'89 Carrera 4
Old 02-03-2008, 07:27 AM
