pete-stevers's Avatar
pmo vs webers
not sure if this question has been beaten into the ground
but i would be interested to hear opinions or comments from people who have run both.
Old 02-10-2008, 03:34 PM
3 restos WIP = psycho
kenikh's Avatar
PMOs are better, especially the 46s. Numerous improvements are cast into the design that Weber machinists have tried to add in over the years. Consider the PMO an "evolved" Weber.
- 1969 911S
- 1980 911SC Targa
- 1979 930
Old 02-10-2008, 05:14 PM
Navin Johnson
TimT's Avatar
PMOs are better
Tell that to the fellow who I was helping get his car running right. At Roebling about a month ago a fellow was *****ing left and right about how his car was running.. we fiddled with the carbs all day and couldnt get the car running correctly
And then there is another fellow I know who took off his PMOs and replaced them with his old Webers....
That solid engine mount disclaimer is a bunch of BS, nice out for PMO
'69 911 GT-5
'75 914 GT-3
and others
Old 02-10-2008, 06:01 PM
Navin Johnson
TimT's Avatar
didnt realize ******ing was a dirty word :S
'69 911 GT-5
'75 914 GT-3
and others
Old 02-10-2008, 06:03 PM
Plavan's Avatar
If you have a choice, PMO's are better.
Chad Plavan
911ST Race Car/2.5L SS Race Motor #02
1972 911T- Numbers matching- Restoring to stock
2011 Porsche Spyder Wht/Blk/Carbon Fiber Buckets/6-Speed (Sold)
2016 Elan NP01 Prototype racecar- Chassis #20, #02
Old 02-10-2008, 06:36 PM
perhaps i should ask not only which one is better but why...
what advantage do webers have that pmo doesn't and vice versa
specifically 40s..
Old 02-10-2008, 08:54 PM
kenikh's Avatar
Sounds like a configuration issue, not a carb issue.
PMOs are basically Weber copies. Their advantage comes in the fact that they have all of the Weber float bowl mods cast right into the parts, plus improved progression circuits among other changes I can't recall.
FWIW, Solexes are actually the best. Better than Webers, better than PMOs. No BS. A Bieker or Duel rebuid later and they are magic. Remote float bowls, non-offset carb bores...what's not to love?
- 1969 911S
- 1980 911SC Targa
- 1979 930
Old 02-10-2008, 09:09 PM
gumba's Avatar
I switched from 46mm Webers to 50 PMO's for the race car and 46 PMO's for the stock 3.2. I noticed the mid range transition was better. The power output seemed the same.
The main reason I switched was Weber 46mm parts are harder and harder to come by. Also finding someone competent in repairing them, and the long lead time for the repairs.
Old 02-11-2008, 08:07 AM
126coupe's Avatar
PMO's I have run both. The webers tend to be temperamental.
I run 46MM on both the 2.5L and the 2.0L The 2.5 has 38MM venturis the 2.0L 36MM venturis. Both sets bolted on and hardly any adjusting. In fact I just put a new set on the 2.0L and did not even have to balance or sync up. Great Product!
1967 911R "Clone" Race Car 2.0 & 2.5 Twin Plug
1984 Mercedes 500 SEC
1991 Mercedes 420 SEL
1992 Ford F-350 Dually
28' Pace Trailer
Old 02-11-2008, 10:10 AM
