pmo vs webers
not sure if this question has been beaten into the ground
but i would be interested to hear opinions or comments from people who have run both. |
3 restos WIP = psycho
PMOs are better, especially the 46s. Numerous improvements are cast into the design that Weber machinists have tried to add in over the years. Consider the PMO an "evolved" Weber.
- 1965 911 - 1969 911S - 1980 911SC Targa - 1979 930 |
Navin Johnson
And then there is another fellow I know who took off his PMOs and replaced them with his old Webers.... That solid engine mount disclaimer is a bunch of BS, nice out for PMO
Don't feed the trolls. Don't quote the trolls ![]() http://www.southshoreperformanceny.com '69 911 GT-5 '75 914 GT-3 and others |
Navin Johnson
didnt realize ******ing was a dirty word :S
If you have a choice, PMO's are better.
Chad Plavan 911ST Race Car/2.5L SS Race Motor #02 1972 911T- Numbers matching- Restoring to stock 2011 Porsche Spyder Wht/Blk/Carbon Fiber Buckets/6-Speed (Sold) 2016 Elan NP01 Prototype racecar- Chassis #20, #02 |
perhaps i should ask not only which one is better but why...
what advantage do webers have that pmo doesn't and vice versa specifically 40s.. Last edited by pete-stevers; 02-10-2008 at 08:58 PM.. |
PMOs are basically Weber copies. Their advantage comes in the fact that they have all of the Weber float bowl mods cast right into the parts, plus improved progression circuits among other changes I can't recall. FWIW, Solexes are actually the best. Better than Webers, better than PMOs. No BS. A Bieker or Duel rebuid later and they are magic. Remote float bowls, non-offset carb bores...what's not to love?
I switched from 46mm Webers to 50 PMO's for the race car and 46 PMO's for the stock 3.2. I noticed the mid range transition was better. The power output seemed the same.
The main reason I switched was Weber 46mm parts are harder and harder to come by. Also finding someone competent in repairing them, and the long lead time for the repairs. |
PMO's I have run both. The webers tend to be temperamental.
I run 46MM on both the 2.5L and the 2.0L The 2.5 has 38MM venturis the 2.0L 36MM venturis. Both sets bolted on and hardly any adjusting. In fact I just put a new set on the 2.0L and did not even have to balance or sync up. Great Product!
1967 911R "Clone" Race Car 2.0 & 2.5 Twin Plug 1984 Mercedes 500 SEC 1991 Mercedes 420 SEL 1992 Ford F-350 Dually 28' Pace Trailer |
