Hopefully Robert will get your ticket. I've been sending a lot of work to him this year and really really like him. Cary, the guy who handles customer service, is really good people too. Been dealing with him for a few years now. I wish I could send all my work to them! But they're not set up for all the mag-case stuff.
Let me know if you need any help w/the build. |
classic case of the while i'm in there diease:) I cast my vote for new rings and hone the jugs. To bad about the woodruff key, everything looks fine on the inside, let me clarify that, from the photos everything looks fine. I was going to suggest you put retaining tubes on the studs to keep the cylinders from moving when turning the crank but it looks like you got that. I rebuilt my 70t awhile back and the help I got here was priceless.
I talked to Robert today, everything is ready. I hope to pick it up on wed.
I picked everything up this morning.
All valve guides & seals replaced, reground valves. One intake valve replaced. Removed 9 exhaust studs and put in inserts. P's & C's measured and ok. Lightly polished crank. Measured rods and they were ok. Well, it was a good day with no bad news. I will try to get some pics. in the next couple of days. |
Heads are done
Polishing a crank involves abrasive compound. It behooves one to insure that none of this compound or residue ends up in the oil passages of the crank. Machine shops often do not clean out these passages.....I have spent hours squirting gallons of fresh solvent thru a crank and it's frightening what comes out. I'm sure my rod & main bearings love me for it.:D I tore apart a low mile engine that someone didn't take this step. 2 rod bearings were on the edge of spinning and one had a piece of crap "prairie dogging" out into a rod bearing causing a deep groove around the circumference of the bearing. |
Thanks JP, I plan on doing a lot of cleaning.
Update
Cams were sent to camgrinder on wed. I am going with 964 grinds. I did not send the rockers, he suggested a using a local machine shop to do those.
camgrinder called today, my cams are ready and will be shipped out tomorrow morning.
That was a lot faster than I thought. |
How much $ do you think you have into this so far? Just curious.
I'd just like to make a comparison: I paid apx. $2500 in Norway, for having my heads reground, and cleaned my cam housings... -Im suffering over here..!
Aurel |
I have just had my six heads cleaned (water blasted), valves and seats reground and lapped, 12 guides installed and head cylinder mating face machined). This cost me $A975. (Perth Head Exchange) Perhaps you guys should move to Perth! |
The heads were cleaned, 12 guides installed, 9 exhaust studs removed and inserts put in, replaced one valve and lapped valves. That was $850. |
I am getting motivated again. ( I have some money to spend)
Here is the plan, tell me what I am missing. boring Alusil 3.2 to 3.4 with 9.5:1 JE pistons 964 cams SW chip cat bypass I plan on replacing just the lower head studs with steel. Rod bolts will probably be aftermarket. (if I screw up I can reuse them):D |
Looks like you are at the same stage I'm at.... Good Luck!
I ve used T Hoff in Raleigh for over 25 engines isn the past few years and the service is always excellent and reasonable..keeps me coming back
You were lucky, usually broken studs results in flycut heads and it throws a kink in the price quote. Bruce |
Please consider upgrading the rod bolts, they are a known weak point.
Going to a 3.4 is a solid plan. I would look at freeing up the exaust side so those cams can achieve there potential. At least a cat bypass and modify the muffler to a twin outlet. Good job. |
Who is doing your Alusil work? I don't mean to be repetitive, but the cylinders need to be modified by a shop with access to the proper Sunnen hone equipment. There is no problem refinishing Alusil as long as the proper stones are used, and the final step involving felt tools with finishing paste. |
The top studs are already steel what would you change them to?
I think he is looking at having his cylinders bored out to 3.4's and replated which should get rid of the Alusil.
I would replace them with whatever your research tells you is best, but I would start with all new studs. Maybe that's what you intended to do, and I didn't understand they way you wrote it. I would have to scan my notes to see what I used last time...they may have been all steel, I just don't remember, and I don't want to speculate. I have seen some builders commenting that doing half the studs in 993 Dilivar isn't a bad decision either. The Dilivar lasted 20 years the first time, there's no reason to suspect it wouldn't continue to provide that level of service now. I don't mean to muddy the waters of you research anymore than to suggest that you have all new studs to start with, even though the steel uppers should be possibly OK.
911st, Nickasil is a coating that can be bored or honed through into a naked cylinder wall. The Nickasil coating can then be reapplied by companies that specialize in that process. Alusil is not a coating. The whole sleeve has the same composition, a monolithic if you will. Using corse stones and a Sunnen hone you can "bore" the cylinders out, but they are still alusil. You must then use a finishing process to raise the silicon (not silicone) particles to the surface. Silicon particles are hard to provide wear resistance, and require a special piston ring. I have spent several weeks of my free time researcing this topic, and there is an overabundance of information and misinformation out there. One easy source of good info is the Porsche 944 and 944 turbo factory service manual, as all 944's had Alusil blocks. You can also still find some information on Kolbenschmidt, the OEM. I do not know if you can Nickasil plate on a bored out Alusil cylinder, I was not aware that you could... maybe someone can set me straight on that. |
Peppy, Good to know. What companies are doing this work? I just remembered seeing the LN engineering display at hershey this year, and they were doing some Nikasil work for boxster engines. I don't remember if they were installing a sleeve, or applying the coating to the cylinder wall. I'll look into it.
You can bore Alusil and coat with Nikasil. I have seen Charles Navarro recommend these guys (link below). If you bore your Alusil cylinders, they will require special iron coated 3.4 pistons, so you will need to source them, in addition to finding someone that can bore your cylinders. It will probabably cost $2k to bore to 3.4 and apply a Nikasil coating and JE pistons. The latter is probably the more common route on this board based on all the threads I have read.
http://www.mt-llc.com/index.html |
Check with EBS in Reno (Engine Builder Supply) I may be wrong but I think having your cylinders bored and plated is about $1k plus about $1k for J&E's.
Also migh check with LN enginering. They also make 102mm cylinders that work with SC & 3.2 motors. http://www.lnengineering.com/911.html |
picture of parts
Oh what a pile of stuff.
http://forums.pelicanparts.com/uploa...1250026997.jpg 964 grind http://forums.pelicanparts.com/uploa...1250027095.jpg She looks so sad http://forums.pelicanparts.com/uploa...1250027171.jpg Shiny parts 3.4JE http://forums.pelicanparts.com/uploa...1250027323.jpg http://forums.pelicanparts.com/uploa...1250027366.jpg Does getting most of the parts mean I am almost there? |
I didnt read all the pages but about the starter. Get one from our host, the hi torque because its smaller. With the G50 you have to lower the front of the trans to get enough clearance to get the nuts off the starter because of the larger bell housing the starter is closer to the floorpan. Suggestion, BTDT
Bruce |
I started today, got the rods out and burnished the ARP rod bolts. I did document the length of the bolts before I started, lots of lube and a couple of hours.
I am hoping this goes smooth. I will post pics and progress as I go. Thanks in advance for all the help on this site. |
http://forums.pelicanparts.com/uploa...1338323101.jpg
My help for the day. http://forums.pelicanparts.com/uploa...1338323129.jpg http://forums.pelicanparts.com/uploa...1338323150.jpg I don't know if the engine was leaking in this many places, but it is where they put JB weld before. I am going to put it back just like it was. http://forums.pelicanparts.com/uploa...1338323158.jpg http://forums.pelicanparts.com/uploa...1338323183.jpg http://forums.pelicanparts.com/uploa...1338323198.jpg[img] http://forums.pelicanparts.com/uploa...1338323978.jpg New thread chasing tool http://forums.pelicanparts.com/uploa...1338324239.jpg |
First -- glad to see you back working on the engine -- this thread is a great read...
Second -- You have a great helper there!! Last -- I learned something new -- JB Weld for case leaks -- does this really work? Regards, Roy T Also currently rebuilding/upgrading a 964 engine for son's 911SC race car... and reading as many engine threads as possible |
The JB Weld he's using is Loctite's version called Hysol 9340. Good stuff.
The engine wasn't leaking in all the places where the epoxy is applied. Is used as a protection against the potential for leaks. All those places on the case are where machining plugs are located (except the spot in the oil cooler location- that's a notoriously thin spot on the casting that frequently leaks) and the epoxy seals the plugs to prevent weeping. The fun is just starting...... Cleaning and prep is one of the hardest parts IMO. Reassembly is pretty straightforward when you've got Wayne's rebuild book and the Bentley Manual +Bruce Anderson's 911 Performance Handbook as a backup Whatever you do, don't cut corners on piston installation. Use a good ring compressor that uniformly compresses the rings all the way around so you can easily slide the piston into the cylinder. You want to lightly oil the rings, piston sides & skirts, and the cylinder, as well as the inner surface of the ring compressor. Then wipe out the excess oil once you've got the piston & cylinder installed & secured to the case with your PVC hold-downs. |
What is a good piston ring compressor (brand,type)? I am going to have to get one.
Well the best kind are the tapered cylinders. They're the cat's meow. I used a 3.870" ARP ring for my 98mm pistons
ARP Tapered Ring Compressors UNIVERSAL 0 - 0 899-8700 But the adjustable clamp style work OK too and they obviously work for more than just one size of piston Pelican Parts.com - Piston Ring Compressor Set |
I just used a Wiseco 98mm tapered ring compressor for the first time and I am a true convert. Given the choice, I would never use one of the adjustables again. The Stomski circlip injector was a worthwhile investment as well.
Thanks for mentioning the Wiseco ring compressor Steve. Same thing as the ARP and quite a bit cheaper!
http://www.wiseco.com/PDFs/Wiseco-CompressorSleeves.pdf Also agree the Stomski injector is the hot setup. Takes a little bit of practice to get the feel for inserting the clip into the tool and also how to best "pull the trigger" to snap the clip into the piston. But once you get the hang of it, it puts a smile on your face every time. No more gouging pistons with picks and screwdrivers during circlip install! |
| All times are GMT -8. The time now is 12:24 AM. |
