beancounter
jwasbury's Avatar
My case does not want to separate
Doing a rebuild on my '79 930:
Jacob's rebuild thread
I'm down to the 'fun part' trying to separate the case halves. In the 'Case Separation' section of Wayne's book, it says "the case should immediately begin to separate" upon tapping with a mallet. Well, that is not what's happening for me. Towards the bell housing end, I think the parting line is separating just a bit...about the width of a mosquito's pecker. On the front side of the engine, I see no evidence of success. The book also uses the term "tapping." Since tapping was not yielding any result, I've tried some whaling as well. Still no go.
I've double and triple checked that all fasteners have been removed. Counted 22 13mm nuts (correct amount per the book), 11 through bolts, 2 15mm nuts under the oil cooler and the super-secret nut inside the chain housing.
I have a couple of theories:
1) Separating case halves is not as easy as it sounds in the book.
2) I need a bigger BFH, like a RBFH
3) Case has been apart before and was re-sealed with some ultra strong 3M adhesive like what dentists use to bond crowns to teeth.
Any ideas folks? I am afraid to continue beating on the case unless I hear that this is not unusual.
Jacob
Current: 1983 911 GT4 Race Car / 1999 Spec Miata / 2000 MB SL500 / 1998 MB E300TD / 1998 BMW R1100RT / 2016 KTM Duke 690
Past: 2009 997 Turbo Cab / 1979 930
Old 09-22-2009, 07:24 PM
dtw dtw is offline
GAFB
Hang it up for the night. Wash up, go to bed. Come back tomorrow.
Ok, you're back? Go around the case and make sure you removed all the aluminum crush washers. They can do an amazing job of hanging up on the studs when they have been over-tightened.
Now, go around the perimeter with your hands and eyes, looking for remaining/forgotten nuts. Forget the nut count. Nuts under the fan strap area? By the breather orifice? Under the flywheel? Bottom of case, nuts facing oppositie direction than rest of nuts? "Death nut" that secures the intermediate shaft bearing saddle (not on perimeter...sorta out in space by itself)?
You already mentioned the chain housing nut and the cooler nuts, guess you're good there.
If you really got all the fasteners, get a length of soft wood and use it as a drift. Plenty of flanges and meaty areas on the case to use it on. Give your hammer good smart raps against the wood. Move around the case in a circle, so you don't get one side cocked up and frozen.
Several BMWs
Old 09-22-2009, 08:32 PM
how about the 10mm inside the left chain area inside the case..It has to be a fastener somewhere..behind the oil cooler?
Should just tap apart
Bruce
Old 09-23-2009, 05:17 AM
beancounter
jwasbury's Avatar
Bruce
That's the "super secret" nut I mentioned. Removed from inside the case where the chain runs. It was an M10 17mm nut in my case. Both 15mm acorn nuts removed from the oil cooler area. Before I posted last night, I went back to the garage and quadruple checked with the book in my hand and verified each of the nuts in the photo had been removed on my case. Is there some 'bonus nut' that isn't in the book? Anything specific to a turbo case that isn't included in the book?
Jacob
Old 09-23-2009, 08:14 AM
Old Member
Make sure to also remove all the washers. They can make separation difficult.
Use a BFH and use it lightly front and back.
Clifton Brown
https://www.mancalamarketing.com
Old 09-23-2009, 09:07 AM
colescrogham's Avatar
Case
2 things I regularly forget: the 2 bolts with nuts (not studs) that have the nuts actually going the other direction than the studs on the bottom at each end of the later cases, and the cover for the intermediate shaft that must be removed before the case can be split in earlier ones.
Another great one to forget is the nut for the long stud by the oil pump. Its located in an odd place on the left side not on the perimeter. They tend to leak and have seen a few almost disappear with a lump of crud over the years.
I don't think the case halves are going to leap apart, but you should be able to get some separation without whaling...
Old 09-23-2009, 09:40 AM
beancounter
jwasbury's Avatar
I'm pretty sure I got all the sneaky nuts on the back side and the one for the oil pump (it's towards the bottom, underneath the cylinders but not on the perimeter).
I will go back and quintuple check that all nuts are removed.
I did have some stuck washers. Started the attempted separation with them in place, and then figured that they could be hanging things up, so I removed them with pliers. Will check again for stragglers.
We'll have another go at it tonight.
Jacob
Old 09-23-2009, 10:18 AM
Alii&Maui
Jesset100's Avatar
Intermediate Shaft End Cover
1982 SC Coupe
SCWDP#0087
KCSSL#0082
Old 09-23-2009, 12:46 PM
resident samsquamch
sand_man's Avatar
As we discussed by phone, earlier:
case splitting tool
Obviously make sure all of the required hardware has been removed....
-jeff
Old 09-23-2009, 03:54 PM
beancounter
jwasbury's Avatar
case splitting tool
Thanks for the link Jeff.
After a stimulating day at the office, a good deal of which was spent obsessing over my rebuild project, I took another crack at this case...literally.
I would love to tell you all how I found a fastener (or intermediate shaft cover) that I previously overlooked and post a nice photo of my crank and oil pump, but I can't.
After checking to insure I've removed all the necessary hardware another 12-15 times, I began beating on the case with my mallet for another half hour...
Looks like my case may be 'special'
That case splitting tool looks like it might be the ticket. I'm intrigued by Henry of Supertec's method, although I don't quite understand the detail and how its supposed to work.
Jacob
Old 09-23-2009, 05:28 PM
beancounter
jwasbury's Avatar
I should add a few data points to this thread. I am a lightweight at about 140lbs. This is my BFH
Perhaps my concept of beating on the case is not enough force? Maybe I need a bigger hammer, or maybe I should put on some weight?
Jacob
Old 09-23-2009, 05:42 PM
Old Member
Show us where you're hitting the case.
Clifton Brown
Old 09-23-2009, 05:44 PM
beancounter
jwasbury's Avatar
I've done the "4 corners" per Wayne's book. I've also hit it around the entire perimeter of the parting line in an effort to break the seal, even though the force of the blow was not in the direction of separating the halves.
Jacob
Old 09-23-2009, 06:18 PM
sounds as if someone used JB weld as a case sealant on it.
Old 09-23-2009, 06:34 PM
beancounter
jwasbury's Avatar
My worst fear
Jacob
Old 09-23-2009, 06:43 PM
Old Member
Put the acorn nuts back on the studs under the oil cooler and the nut back on the stud under the driver's side chain case.
Try hitting the acorn nuts and the front stud (nut) with your hammer alternately. Use an old socket extension or brass drift to reach the front stud.
Clifton Brown
Old 09-23-2009, 06:49 PM
TibetanT's Avatar
Subscribing...
Ed Paquette
1983 911SC
1987 944S
1987 944 Manual (Donated to the Nat. Kidney Foundation)
1987 944 Automatic (Recently sold to another Pelican)
Old 09-23-2009, 09:43 PM
Just a thought...
If its been sealed, or glued, or JB welded... then a propane torch should seperate it...
Even JB weld fails at 600 degrees or so, right?
Old 09-24-2009, 10:29 AM
beancounter
jwasbury's Avatar
So it says on their website...I checked it.
I've got a plan for a splitting tool similar to what was done in the 'case splitting tool' thread link posted above. I just can't take this prehistoric $hit any longer:
I'll also have my propane torch handy...stay tuned.
Jacob
Old 09-24-2009, 11:43 AM
Fast Corners's Avatar
Wow, that is just too damn funny!
FC
'73 911 Track Car
'99 996 Daily Driver
'93 968 Wife's Car
'05 Cayanne S Family Car
Old 09-24-2009, 12:17 PM
