difference between 3.2 and 3.0 crankcases
Hi Everyone,
I'd like to know what the difference between a 3.2 and 3.0 crankcase.
Can you transfer a 3.0 engine into a 3.2???
Regards
Isaac
Old 05-23-2008, 09:05 PM
Try not, Do or Do not
Henry Schmidt's Avatar
The main difference is the 3.0 and early 3.2 cases have a sump cover for access to the oil pump screen. The 3.2 and all later air cooled 911 cases were cast without this access cover.
The parts from your 3.0 will transfer into a 3.2 or 3.3 case for that matter, without issue. I would of coarse replace the SC pump with a 3.2 or newer pump.
There are some bosses on the 3.2 case that make going the other direction (3.2 in a 3.0 case) a little more of a challenge.
Henry Schmidt
SUPERTEC PERFORMANCE
Ph: 760-728-3062
Email: supertec1@earthlink.net
Old 05-24-2008, 10:36 AM
thanks for the reply,
now I can rest as ease.
Regards Isaac
Old 05-24-2008, 05:00 PM
