Torn Down ready to hit the machine shop
Hi guys well I have the motor torn all the way down now, took me about 8 hours over a few days what with kids and other s*%t. Thankfully the cams both look ok, crank looks good, both case halves ok. So tomorrow I am off to the machine shop and just looking for some advise as to what else to have them check.
Current plan is to have them bead blast the case halves. Check the crank bore for alignment and ID Magnaflux and polish the crank Magnaflux the cams prior to re-gring to 964 specs Anything else I should be doing? Oh and hows this the X5 had to be towed to the dealer Saturday last week as the car told me oil pressure low. Got a call from the service dept telling me the enigne is sludged up????? WTF says I car only has 20,000kms on it? Upshot is engine is toast new one being shipped from Germany as I type. Not having much luck with motors these days!!!!
Davy 82 911 SC Targa Sold 12 Audi A5 Sportback 3.0 TDI Quattro 03 996 C4S Last edited by Daviboy; 05-06-2010 at 11:25 AM.. |
Davy,
Consider haveing the Chain boxes milled to accept the later 3.2 style gaskets. G2 performance faced my rockers and polished the shafts for me. Craig did a very nice job, fast turn around. Shane
78’ SC 911 Targa - 3.2SS, PMO 46, M&K 2/2 1 5/8” HEADERS, 123 DIST, PORTERFIELD R4-S PADS, KR75 CAMS, REBEL RACING BUSHINGS, KONI CLASSICS |
Dont bead blast the case, too much leftover hanging around you cant get out of the nooks and crannies.
Bruce |
The case can be soda blasted or tumbled to clean it up.
Tom Butler 1973 RSR Clone 1970 911E - Sold but Never Forgotten 914-6 GT Clone |
3 restos WIP = psycho
Tumbled is the way to go - the results are stunning.
- 1965 911 - 1969 911S - 1980 911SC Targa - 1979 930 |
Thanks for the replies guys. I contacted a good local shop today who do most everything I am looking for so I am off to see then monday. Looks like I may have a deal on P&C's as well within budget so thngs are looking up.
Davy 82 911 SC Targa Sold 12 Audi A5 Sportback 3.0 TDI Quattro 03 996 C4S |
X2. I had mine done and it turned out PERFECT! Hell, I had a complete 901 transmission done also (Put a normal 14mm bolt in place of the breather). Looks great. I would post pics but it is at the engine builders
FYI, it only cost $200 for every alum engine part and the complete trans! I had them just use tiny plastic cleaning media so it didnt polish it too much. Looks like new!
1997 C4S stock...ish 1970 911T Restored Hot Rod....Sold ![]() http://forums.pelicanparts.com/porsche-911-technical-forum/418411-here-my-new-old-project-lilly.html |
What exactly is "tumbling"? I googled and came up with a myriad range of stuff but nothing that was related.
Thanks. |
Tumbling is a large vibratory bowl that can have different types of media in it.
Tumble finishing - Wikipedia, the free encyclopedia The part gets put in the large bowl and the small pieces of media vibrate around it and clean and/or polish it. It depends on the type of media. They did mine with a plastic media so that it only cleaned it. I wish I had pictures but my cases turned out amazing! They can also use rough ceramic ones that will actually give aluminum a very very shiny polished look. It is actually pretty amazing. Here is a Pic of an old 901 that I had done complete. It was greasy and nasty before I gave it to them. They could have gotten it better but it wasnt necessary.
That's very cool. Thanks. Now I have to see if there is such a place near me.
