Piston identification !
Could anyone please shed some light regarding to what comp. ratio is the following piston ? Is from a European SC but not sure about the year.
Inside the piston markings : MAHLE, +93L7, CO11
Cylinder markings : MAHLE m, 95zn1w1
TIA,
Jim
Old 07-25-2008, 12:25 PM
Jim
93L7 is the standard 8.5 CR Mahle Nikasil piston.
I have a box full of these with matching cylinders if you need a few.
Tom Butler
1973 RSR Clone
1970 911E
914-6 GT Recreation in Process
Old 07-25-2008, 06:37 PM
Jim
The 93L7 is the Mahle 8.5 CR piston for the 3.0 SC
For reference, the Mahle 9.3 CR for the 3.0 SC is - 95L67
The Mahle 9.8 CR for the 3.0 SC is - 95L70.
Here's some pics:
8.5 CR - 93L7
9.3 CR - 95L67
9.8 CR - 95L70
Tom Butler
1973 RSR Clone
1970 911E
Old 07-26-2008, 02:54 AM
laughac's Avatar
Send a message via AIM to laughac
I'm told these will fit into my 2.7 block even though they came from 3.0.
Can anyone help confirm this?
Cylinders have "MAHLE G**" cast on one side & "95ZN1W4" on the otherside, 11 fins.
On the inside of the pistons, "Mahle" "93L7" "++" "CO11"
2000 Boxster S
2004 330ci convertible
1978 450 SLC
1924 Model T Ford touring
Fleet of Ford Buses, Sedans, SUVs and Limos
Old 01-17-2011, 09:56 PM
Will not fit
Old 01-18-2011, 05:46 AM
The headstuds are farther apart on the 3.0 and up.
Old 01-18-2011, 09:08 PM
laughac's Avatar
Thank you.
Somebody confused me with a big bore kit they said would fit the 2.7 crankcase.
2000 Boxster S
1978 450 SLC
Old 01-18-2011, 09:44 PM
Big bore kits for the 2.7 is the 92mm 2.8 and I think there was 2.9 also but the walls have to get pretty thin. I ve never seen a 2.9 but heard of them.
Bruce
Old 01-19-2011, 04:53 AM
