JoeMag's Avatar
How can you clean fuel rails?
Have some fuel rails I'm going to be using and I notice rust forming in them. Can these be cleaned up? If so, where?
Old 07-29-2008, 09:49 AM
3.2 CAB's Avatar
Are they the ones used on a 3.2? If so, you can clean them at home just fine. Make sure to plug all of the holes, so you don't get any crap or anything else, inside the fuel rails. I have used a soft, wire wheel, brush either on my bench grinder or on one of my angle or side-grinders. Clean the rusted spots down to clean metal and give the rest a good general cleaning. If you want a "factory new"type of look, there are paint kits that will closely resemble the original yellowish colored, cadmium plating. If not that, you could prime and then use almost any color of paint for engines or transmissions, due to the heat that the fuel rails will be subjected to. It should come out really nice. Good luck!! Tony.
84' Steelslantnose Cab.
1953 Dodge B-4-B-108" 90,127 miles
1953 Dodge B-4-C-116" 58,146 miles
1954 Dodge C-1-B8-108" 241V8 POLY
1973 Roadrunner 440-SIX-PACK*
1986 F-250 Super Cab-460 V8 tow
Newest additions-
Matching numbers 1973 340 Road Runner!!
1948 Dodge B-1-F-152" 1-1/2 ton Dump body, 39,690 miles
others...
Old 07-29-2008, 10:17 AM
JoeMag's Avatar
...to clarify. The INSIDE of fuel rail has some rust forming.
Old 07-29-2008, 11:00 AM
3.2 CAB's Avatar
Ohhh,... OK. That is a totally different matter. I don't have an answer for you on that.
Newest additions-
others...
Old 07-29-2008, 05:46 PM
abit off center
cgarr's Avatar
You been running a lot of fuel with alcohol in it? May have since thats about all you can get now. Most likely your tank and lines are a but rusty too. You could shake some lead or steel shot in it to clean it up but its going to come right back I would guess. I always run a shot of MM oil with the fuel.
______________________
Craig
G2Performance
Old 07-29-2008, 06:23 PM
JoeMag's Avatar
Craig -- intestesting thought. ...i have no idea what was run in these. they've been off what ever car they came from for a while. what is MM oil?
Old 07-30-2008, 08:32 AM
abit off center
cgarr's Avatar
MM=Marvel Mystery Oil
Craig
G2Performance
Old 07-30-2008, 08:41 AM
