jasam's Avatar
Ring problems
Hi, I'm in the middle of the rebuild but my mechanic says that the piston rings fit a little bit bigger than they should. It was everything perfect std size, I ordered the rings from our host and when I got them they said 85mm but I thought it was a misprint, nevertheless I'm worried about my car losing Compression...
I don't know maybe they will just fit correctly but confirmation would not hurt.
Thanks for any recommendation...
John
There is no substitute
Old 08-05-2008, 09:43 PM
jasam's Avatar
1970 2.2 T engine
Old 08-06-2008, 07:37 AM
304065's Avatar
Ok, a stock 2,2T has 84mm cylinders. Unless the cylinders were bored out to 85mm, 85mm is the wrong ring. Measure the cylinders with a bore gauge and determine the right size rings, then install those with the factory-recommended ring gap.
Ring gap is customarily measured by placing the ring in the bottom of the cylinder, leveling it out (a piston can be used for this) and placing a feeler gauge in the gap.
'66 911 #304065 Irischgruen
‘96 993 Carrera 2 Polarsilber
'81 R65
Ex-'88 Carrera (Sold 3/29/02)
Old 08-06-2008, 08:09 AM
jasam's Avatar
They are 84mm and in perfect condition but I don't know about the rings, I though it was a label misprint but shall I considered that our host sent me 85 mm rings ? I don't even see him selling those...
It it a T engine with 'E' P/C, Cams
My mechanic said that the originals fit even better than the new ones, therefore IM WORRIED, LOL
Old 08-06-2008, 08:16 AM
jasam's Avatar
I have the details of the rings..
Factory suggested Ring gap .006 - .039
Actual ring gap (of the new rings) .019
Used piston rings gap .017...
what can I do in this case?
do you know where can I find the right rings if these do not work?
thanks again for your help
Old 10-30-2008, 03:06 PM
.006 -.017 is the factory range. do you have goetze rings or deves?
206 637 4071
Old 10-30-2008, 07:30 PM
jasam's Avatar
goetze and the ring gap they have it is .019.. I bought them form our host
the used ones had .017 and it smoked a little bit..
what you think
Old 10-30-2008, 08:02 PM
I had the same problem with a set of 90mm rings from Goetz. I ended up using the old rings and returning the "new" rings. I don't know why they send rings with big gaps.
-Andy
Old 10-31-2008, 09:08 AM
jasam's Avatar
but then I wont be able to fix the smoking problem... it did smoke a little bit and I want it perfect... shall I buy another set and pray for them to be ok?
Old 10-31-2008, 02:22 PM
jasam's Avatar
Would there be any difference between Mahle rings and goetze?
Old 11-01-2008, 07:36 PM
