Ring problems
Hi, I'm in the middle of the rebuild but my mechanic says that the piston rings fit a little bit bigger than they should. It was everything perfect std size, I ordered the rings from our host and when I got them they said 85mm but I thought it was a misprint, nevertheless I'm worried about my car losing Compression...
I don't know maybe they will just fit correctly but confirmation would not hurt. Thanks for any recommendation... John
There is no substitute |
Author of "101 Projects"
Need more info, which engine are we talking about here?
-Wayne
Wayne R. Dempsey, Founder, Pelican Parts Inc., and Author of: 101 Projects for Your BMW 3-Series • 101 Projects for Your Porsche 911 • How to Rebuild & Modify Porsche 911 Engines • 101 Projects for Your Porsche Boxster & Cayman • 101 Projects for Your Porsche 996 / 997 • SPEED READ: Porsche 911 Check out our new site: Dempsey Motorsports |
1970 2.2 T engine
Ok, a stock 2,2T has 84mm cylinders. Unless the cylinders were bored out to 85mm, 85mm is the wrong ring. Measure the cylinders with a bore gauge and determine the right size rings, then install those with the factory-recommended ring gap.
Ring gap is customarily measured by placing the ring in the bottom of the cylinder, leveling it out (a piston can be used for this) and placing a feeler gauge in the gap.
'66 911 #304065 Irischgruen ‘96 993 Carrera 2 Polarsilber '81 R65 Ex-'71 911 PCA C-Stock Club Racer #806 (Sold 5/15/13) Ex-'88 Carrera (Sold 3/29/02) Ex-'91 Carrera 2 Cabriolet (Sold 8/20/04) Ex-'89 944 Turbo S (Sold 8/21/20) |
They are 84mm and in perfect condition but I don't know about the rings, I though it was a label misprint but shall I considered that our host sent me 85 mm rings ? I don't even see him selling those...
It it a T engine with 'E' P/C, Cams My mechanic said that the originals fit even better than the new ones, therefore IM WORRIED, LOL
I have the details of the rings..
Factory suggested Ring gap .006 - .039 Actual ring gap (of the new rings) .019 Used piston rings gap .017... what can I do in this case? do you know where can I find the right rings if these do not work? thanks again for your help
.006 -.017 is the factory range. do you have goetze rings or deves?
goetze and the ring gap they have it is .019.. I bought them form our host
the used ones had .017 and it smoked a little bit.. what you think
I had the same problem with a set of 90mm rings from Goetz. I ended up using the old rings and returning the "new" rings. I don't know why they send rings with big gaps.
-Andy
72 Carrera RS replica, Spec 911 racer |
but then I wont be able to fix the smoking problem... it did smoke a little bit and I want it perfect... shall I buy another set and pray for them to be ok?
Would there be any difference between Mahle rings and goetze?
