Try not, Do or Do not
Supertec 3.1 liter Short Stroke 9000 RPM 2 valve
1982 930 Turbo case (GT3 squirters) Shuffle pins Boat Tail Supertec SuperCrank billet 66mm full cross drilled R&R billet connecting rods (GT3 config: 53mm big end, 21mm small end & 130mm oal) GT3 Bearings coating by Calico Coating 996 TT oil pump Racing IWIS chains Supertec idler arms 964 steel countershaft Supertec Head studs LN Nickie cylinders 100mm Supertec 906 cooling tin 10:1 JE FSR pistons, 60 grams lighter than conventional pistons Custom DC 80 cams Early forged rockers w/dry film pads Extreme Cylinder heads Port Flow Analyzer v3.0 EXTREME CYLINDER HEADS Test Comments: Vlv Dia 1.850" 1.575" Stem Dia.31" Lift Range Test Flow Leak Corr Pres Pres CFM Int #1 .100 4 28.00 34.00 .0 67.7 Int #1 .200 4 28.00 79.00 .0 157.2 Int #1 .300 5 28.00 73.50 .0 216.8 Int #1 .400 5 28.00 84.00 .0 247.8 Int #1 .500 5 28.00 89.50 .0 264.0 Exh #1 .100 4 28.00 25.00 .0 51.3 Exh #1 .200 4 28.00 53.00 .0 108.7 Exh #1 .300 4 28.00 75.00 .0 153.8 Exh #1 .400 4 28.00 87.50 .0 179.4 Exh #1 .500 4 28.00 93.00 .0 190.7 50mm PMO Carbs (manifolds 41 x 50mm) Burnham Motorsport Twin plug distributor Burnham Motorsport sump cover Series 900 fan shroud Supertec Power Pulley Supertec RSR flywheel ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]()
Henry Schmidt SUPERTEC PERFORMANCE Ph: 760-728-3062 Email: supertec1@earthlink.net Last edited by Henry Schmidt; 05-12-2013 at 07:29 PM.. |
Henry Schmidt SUPERTEC PERFORMANCE Ph: 760-728-3062 Email: supertec1@earthlink.net |
![]() ![]() ![]() ![]() ![]() ![]() I forgot to mention: Extreme Cylinder valve springs and titanium retainers Hargett valve covers M&K RSR muffler Ceramic coated 1 3/4 German Racing headers Custom wiring harness by Supertec Performance
Straight shooter
Porn-sche. Looks fantastic.
“Of the value traps, the most widespread and pernicious is value rigidity. This is an inability to revalue what one sees because of commitment to previous values. In motorcycle maintenance, you MUST rediscover what you do as you go. Rigid values makes this impossible.” ― Robert M. Pirsig, Zen and the Art of Motorcycle Maintenance: An Inquiry Into Values |
Now that's a proper short stroke
Aaron. F.S. 1965 Solex engine w carbs/cleanerBurnham Performance https://www.instagram.com/burnhamperformance/ |
Cool - what sort of HP at which RPM do you expect (and RPM at peak TQ)?
2022 GT3 Manual, 73 Carrera RS 2.9 Twin-Plug MFI Carbon Fiber Replica Former: 18 GT3 Manual,16 Cayman GT4, 73 911S, Two 951S's, 996 C2, 993 C2, BMW 635CSi Euro, Ferrari 550 Maranello, 06 Evo IX w/ many mods |
Schleprock
SHAZAM............. That's hot.
If someone asks whether you used the cam oil line restrictors, you have my permission to internet-punch them. ![]() What type of intake valve covers are those?
Kevin L '86 Carrera "Larry" |
Would look nice in a well set up 944...
I must take a cold shower now... Beautiful!! |
Yes please.
Pete 79 911SC RoW "Tornadoes come out of frikkin nowhere. One minute everything is all sunshine and puppies the next thing you know you've got flying cows".- Stomachmonkey |
I wanted to use a better set of headers but at some point you have to just run it and see what you get.
WOW... Now I'll need to buy another car so I have an excuse to have you build one for me
1970 911E Sportomatic Albert Blue 1971 911T Sunroof Coupe w/ Twin Plug 2.5 MFI 1973 911E Glacier Blue 1973 911E RSR Tribute Viper Green w/ 3.5 Twin Plug MFI |
This is nothing but pornography and should be banned - banned I say.
914/6 GT (Repro) Tarmac Rally car 928 S4 - 1989 911SC - 1980 944 TURBO - 1986 944 S2 - 1990 |
Henry,
Amazing! You just keeping pushing the envelope on engine design. Vr, Scott
Bavaria911 1970 911T w/ 2.4S 1971 911T Targa w/ 2.2 RG Member # 818 |
I see headers being a limitation. We saw 18whp more with a custom set of stepped headers then 15/8" euro George's on a mostly stock 3.2L and we were able to pull timing out and maintain power. I would think there are probably larger gains to be had with big cams.
None the less. SWEET engine. Any reason other then cost why you aren't using Ti GT3 rods? I was given a set and have been salivating over getting them into my 3.0L. Last edited by Evan Fullerton; 05-08-2013 at 09:51 PM.. |
Beautiful job.......
As always, a beautiful job! I know the owner of this engine will be a proud papa!
FEC3 1980 911SC coupe "Zeus" 3.3SS god of thunder and lightning |
Cylinder air shrouds
Just noticed that the ones on your engine look different than the ones off my 3.0 SC engine. Are they more efficient? Something you make in your shop? Are they available to us mere mortals?
Thks,
Less brakes, more gas!
He makes them. I have them on my 3.0l. I believe they are 904 inspired or something like that.
Michael ![]() '82 Euro SC 'Track Rat' 22/29 Hollows, 22/22 Tarrets, Full ERPB F/R, Rennline Tri Brace, Glass bumpers, Pro 2000's, 5 pts, blah blah blah '13 Cayenne GTS |
Plus, I really like the R&R rods that Charles @ LN Engineering sells.
