I told you this guy is good.. When i asked him what he did to that 3.2. his answer was "EVERYTHING"..Heavily modified heads,own camshafts.. but there´s no doubt the engine made that kind of power/torque. Have a look at the other engines he built/dynoed-same pattern..
Old 12-23-2011, 10:55 AM
blakey's Avatar
Originally Posted by 304065 View Post
Jamie, back to your questions about specific output, here is some historical data from Bruce Anderson's book about the engine types over the years. This is a good starting point for the discussion about power-to-weight-- the next step is to look at the cams, intake ports, valve sizes and other modifications necessary to achieve these numbers.
excellent list! Wonder if it's found somewhere in text format
Old 12-24-2011, 12:30 PM
