Smith
Send a message via AIM to robrob10
Don't Know what part this is
all I know is that the part on top fits through the part on bottom
this would go to a 1980 911 sc
Old 03-08-2009, 04:11 PM
Navin Johnson
TimT's Avatar
looks like the oil pump pick up...
question is how did it become separated from the oil pump?
The pick up tube epoxies into the oil pump.... have seen a few that have been knocked loose...
'69 911 GT-5
'75 914 GT-3
and others
Old 03-08-2009, 04:28 PM
Smith
I believe that when the person that owned the cer before me brought it to the dealership this is what they removed from the car along with the oil sump plate. Do you think that maybe it got knocked loose and the dealership took it out?
-smith
Old 03-08-2009, 05:20 PM
Smith
also what do you mean by epoxies to the oil pump?
Old 03-08-2009, 05:23 PM
Navin Johnson
TimT's Avatar
Meaning that tube is glued (epoxied) into the oil pump housing...
Post a pic of your oil pump if you have a chance?
'69 911 GT-5
'75 914 GT-3
and others
Old 03-08-2009, 05:27 PM
Smith
oh ok.
sorry, but where is the oil pump exactly? im kind of a rookie
Old 03-08-2009, 05:44 PM
Smith
Originally Posted by robrob10 View Post
oh ok.
and I can definately get a pic if I can find it.
Old 03-08-2009, 05:46 PM
The second piece is part of the update screen circa 1980 that the pickup sits into.Replaced the screen filter of the earlier years. The update helped maintain oil pickup in hard corners
Bruce
Old 03-08-2009, 07:12 PM
Free minder
Aurel's Avatar
To access the oil pump, you need to split the case.
1978 SC Targa, DC15 cams, 9.3:1 cr, backdated heat, sport exhaust https://1978sctarga.car.blog/
2014 Cayenne platinum edition
2008 Benz C300 (wife’s)
2010 Honda Civic LX (daughter’s)
Old 03-08-2009, 08:03 PM
pieces
That is the scavenge pickup for the oil pump, if that fell off while running all the oil ended up in the engine and starved it with nothing in the tank, the scavenge side of the pump's job is to pull the oil that has been thru the engine and put it back in the tank. I have seen those loosen up where they are glued in but the way it fits into the screen kind of holds it from "falling out" when you drop the sump plate and screen its possible to silp it out of the pump if the epoxy is free. did you find metal in the engine, noise, hi oil temp ?
Mike Bruns JBRacing.com
The two most useless things to a driver are the braking distance behind you and nine-tenths of a second ago.
Old 03-09-2009, 05:26 AM
Smith
yes there was metal in the engine, there was noise, but I don't know about the hi oil temp.
so i'm guessing I want to put these back into their proper spot? do I access this spot through the oil sump plate?
Old 03-09-2009, 05:31 PM
Navin Johnson
TimT's Avatar
Not to sugar coat it, but you probably have to rebuild the engine....
Split the case, have the components visually inspected, measured for tolerance.. If the oil pump is still good... you can epoxie the pick up back into the oil pump housing...replace all the worn components... etc...
'69 911 GT-5
'75 914 GT-3
and others
Old 03-09-2009, 05:42 PM
damage
I would take the engine apart and hopefully it can be rebuilt, putting the pump pickup back in place and starting it just to confirm its hurt bad might not leave you much more than the heads and valve covers, Just be sure to flush and clean the entire oil system, tank,front cooler,lines all of it before the new/repaired engine starts, toss or ultrasonicly clean the engine oil cooler. Best of luck, let us know if you have a question
Mike Bruns
Old 03-09-2009, 06:50 PM
Smith
great thanks for the advice, but would there be any reason other than these parts simply coming loose, that the dealership might have taken these off for any reason?
Old 03-10-2009, 06:05 PM
Navin Johnson
TimT's Avatar
No...
These pieces are not part of any sort of maintenance schedule etc....
Considering some of the other symptoms you mentioned... i.e. noise, and metal in the engine..
I would do a ground up rebuild on the engine...
'69 911 GT-5
'75 914 GT-3
and others
Old 03-10-2009, 07:02 PM
The last time I saw that pipe on it's own was after it had fallen out, run through the engine and broken a timing chain.
It was very expensive to repair.
From November 2012; Precision Porsche Specialist
Sussex UK, +44 (0)1825-721-205
2001-2012 Gerber Motorsport Inc. 206-352-6911
07.15.06 1996 Ducati 900SP. Suprisingly enough, it's red
08.16.09 1999 Kawasaki ZRX1100. Green.
Old 03-11-2009, 02:18 PM
