3 restos WIP = psycho
kenikh's Avatar
Dizzy and crankfire combo for twin plugs
Can you drive ignition to stock distributor off of a crankfire system like a TEC1, HPX or HPV1? My interest is in using the stock dizzy to drive the top plugs and a coilpack to drive the bottom set of plugs on a twin plug motor. You could clearly do this with the two systems (dizzy and crankfire) tuned in isolation, but really would like them to leverage the same curve/ignition data source.
Grady mentioned something like this a few years ago, but the details elude me.
- 1969 911S
- 1980 911SC Targa
- 1979 930
Old 10-19-2008, 08:18 AM
Well,...one would need a trigger wheel and sensor to drive any Electromotive product and that requires either a bolt-on wheel or special lower pully such as the Clewett ones.
The stock distributor will not fire any of these units so you are faced with building a hybrid ignition setup that will be rather challenging to tune well.
If I recall, Grady's system used a separate distributor, modified to be driven off the left camshaft drive. Not easy to time, either.
FWIW., I do have some better ideas but none of them are what people would characterize as inexpensive,....
Steve Weiner
Rennsport Systems
Portland Oregon
(503) 244-0990
porsche@rennsportsystems.com
www.rennsportsystems.com
Old 10-19-2008, 01:02 PM
kenikh's Avatar
The solution I recall is using the stock dizzy and a crankfire computer to do what Motronic does: use the toothed wheel for the computer/curve and use a dizzy as a dumb spark distributor. You then add a coil pack for the plugs not driven from the dizzy. This solution would give a twin plug option that looks stock and drives the plugs from one curve/advance source. As you can probably tell, cheap is my goal. You can find a single plug HPV1 for under $500.
- 1969 911S
- 1980 911SC Targa
- 1979 930
Old 10-19-2008, 01:31 PM
Noble goal indeed, but it cannot be done well for "cheap,...
Steve Weiner
Rennsport Systems
Portland Oregon
(503) 244-0990
Old 10-19-2008, 01:35 PM
Try not, Do or Do not
Henry Schmidt's Avatar
Here's another option.
Use a distributor to send a signal to a signal MSD box. Use the MSD to trigger two coils. The two coils to send a spark to the stock dist. and the cam driven dist.
The cam driven distributor will need to be fabricated but the cost would be minimal.
Here is a cam driven distributor that was used on a version of the 930 . It incorporated both distributor and turbo scavenge pump.
It could be design sans oil pump.
Henry Schmidt
SUPERTEC PERFORMANCE
Ph: 760-728-3062
Email: supertec1@earthlink.net
Old 10-19-2008, 02:12 PM
Interesting setup Henry - do you have a Bosch part number for the screw down 6 plug distributor cap ??
I thought I'd seen this posted previously as 962 ?? (or 956 ?)
Regards,
John
Old 10-19-2008, 02:37 PM
kenikh's Avatar
My basic question still stands unaswered: If a 3.2/3.6 Motronic can use a toothed wheel (albeit off of the flywheel) and computer with a distributor to send spark, why can't an aftermarket crankfire system be used to do the same?
- 1969 911S
- 1980 911SC Targa
- 1979 930
Old 10-19-2008, 02:59 PM
You can, but not using Electromotive hardware,....
Steve Weiner
Rennsport Systems
Portland Oregon
(503) 244-0990
Old 10-20-2008, 09:27 AM
kenikh's Avatar
So big bucks systems like Motec only, then...got it.
- 1969 911S
- 1980 911SC Targa
- 1979 930
Old 10-20-2008, 09:28 AM
Old 10-20-2008, 02:10 PM
Regards,
John
Same concept different part.
Henry Schmidt
Ph: 760-728-3062
Old 10-20-2008, 05:20 PM
