3 restos WIP = psycho
Dizzy and crankfire combo for twin plugs
Can you drive ignition to stock distributor off of a crankfire system like a TEC1, HPX or HPV1? My interest is in using the stock dizzy to drive the top plugs and a coilpack to drive the bottom set of plugs on a twin plug motor. You could clearly do this with the two systems (dizzy and crankfire) tuned in isolation, but really would like them to leverage the same curve/ignition data source.
Grady mentioned something like this a few years ago, but the details elude me.
- 1965 911 - 1969 911S - 1980 911SC Targa - 1979 930 |
Well,...one would need a trigger wheel and sensor to drive any Electromotive product and that requires either a bolt-on wheel or special lower pully such as the Clewett ones.
The stock distributor will not fire any of these units so you are faced with building a hybrid ignition setup that will be rather challenging to tune well. ![]() If I recall, Grady's system used a separate distributor, modified to be driven off the left camshaft drive. Not easy to time, either. FWIW., I do have some better ideas but none of them are what people would characterize as inexpensive,....
Steve Weiner Rennsport Systems Portland Oregon (503) 244-0990 porsche@rennsportsystems.com www.rennsportsystems.com |
The solution I recall is using the stock dizzy and a crankfire computer to do what Motronic does: use the toothed wheel for the computer/curve and use a dizzy as a dumb spark distributor. You then add a coil pack for the plugs not driven from the dizzy. This solution would give a twin plug option that looks stock and drives the plugs from one curve/advance source. As you can probably tell, cheap is my goal.
You can find a single plug HPV1 for under $500.
Try not, Do or Do not
Here's another option.
Use a distributor to send a signal to a signal MSD box. Use the MSD to trigger two coils. The two coils to send a spark to the stock dist. and the cam driven dist. The cam driven distributor will need to be fabricated but the cost would be minimal. Here is a cam driven distributor that was used on a version of the 930 . It incorporated both distributor and turbo scavenge pump. It could be design sans oil pump. ![]() ![]() ![]()
Henry Schmidt SUPERTEC PERFORMANCE Ph: 760-728-3062 Email: supertec1@earthlink.net Last edited by Henry Schmidt; 10-19-2008 at 02:14 PM.. |
Interesting setup Henry - do you have a Bosch part number for the screw down 6 plug distributor cap ??
I thought I'd seen this posted previously as 962 ?? (or 956 ?) Regards, John |
My basic question still stands unaswered: If a 3.2/3.6 Motronic can use a toothed wheel (albeit off of the flywheel) and computer with a distributor to send spark, why can't an aftermarket crankfire system be used to do the same?
So big bucks systems like Motec only, then...got it.
Same concept different part.
Henry Schmidt SUPERTEC PERFORMANCE Ph: 760-728-3062 Email: supertec1@earthlink.net |
