911914
Acceleration On Rebuilt Motor
I have been slowly breaking in my 911SC motor and now that I have reved it up to 5000 rpm the acceleration is not a quick prior to the rebuild. Any advice?
Old 10-31-2008, 02:50 PM
otto in norway's Avatar
Hey..
I suspect you have not set the timing right...? ( 5 deg. BTDC)
If not, check the ignition on each cylinder, cam timing, and so on...
Old 10-31-2008, 05:02 PM
911914
Thanks, Would using Bosch platinum cause a problem?
Old 10-31-2008, 05:08 PM
Sorry, never heard of it, so I don't know...
Old 10-31-2008, 05:29 PM
Max Sluiter
Flieger's Avatar
Bosch Platinums are typically too "hot" for old air-cooled Porsche flat-sixes. This can cause detonation due to the heat retained in the cylinder head. Detonation/misfiring can cause poor acceleration.
On the other side, too "cold" of a plug can cause plug fouling, which will cause poor running all over the rev range but can clear up when pushing it hard. It would re-appear at idle.
If your engine idles smoothly but is down on power, maybe it is detonation from too hot a plug? The cold ambient temperature would lead to leaner air/fuel ratios...
Old 10-31-2008, 07:43 PM
Manassas, VA
lucittm's Avatar
Flieger,
I beg to differ. Bosch platinum plugs can be had in a wide variety of heat ranges. Often the platinum type plug is not required but this alone will not change the heat range of the plug.
My car came from the factory with Bosch platinum plugs and that is what I currently run.
Before you suggest that a plug is "too hot" you would have to know the designation on the plug. If it was a WR9DP0, I might agree with you, assuming a stock engine of course.
Transformer,
What is the designation of your Bosch platinum plugs?
Thanks,
Mark
1991 964 Polar Silver Metallic Turbo Coupe
Old 10-31-2008, 08:15 PM
Wer bremst verliert
JohnJL's Avatar
How about this..what do your plugs look like?
Do you have access to/can you borrow an AFR and check you mixtures?
2007 911 Turbo - Not a toy
1985 911 Cab - Wife's toy
1982 911 3.2 Indiash Rot Track Supercharged track toy
1978 911 3.0 Lichtbau toy "Gretchen"
1971 911 Targa S backroad toy
Old 10-31-2008, 11:24 PM
Air Medal or two
afterburn 549's Avatar
firing order..............
D troop 3/5 Air Cav,( Bastard CAV) and 162 Assult Helicopter Co- (Vultures) South of Saigon, U Minh Forest, Delta, and all parts in between
Old 11-08-2008, 09:49 PM
Less brakes, more gas!
euro911sc's Avatar
How many miles on the build? Mine was a little slow for a bunch then seemed to kick in around 500 miles... I suspect the rings seated at that point and I'm now getting decent compression. Perhaps your rings have not seated yet?
-Michael
Michael
'82 Euro SC 'Track Rat' 22/29 Hollows, 22/22 Tarrets, Full ERPB F/R, Rennline Tri Brace, Glass bumpers, Pro 2000's, 5 pts, blah blah blah
'13 Cayenne GTS
Old 11-09-2008, 06:18 AM
kodioneill's Avatar
where in ny are you located?
1974 sahara beige 911 targa
1982 chiffon 911sc
1985 prussian blue metallic carrera
Old 11-09-2008, 08:18 AM
