7 R case work complete I hope?
Hi guys,
some snaps of my 7 R cases with machine work completed . Unless you tell me I may need more. ?
They will form the basis of a 2.7 twin plug 10:5 / 1 engine with TB's and S cams .
Work illustrated is oil pump by pass, shuffle pinning, case savers and some windage work.
Old 11-21-2008, 05:05 AM
juicersr's Avatar
That case should be quite robust. Why not go all out and build a 2.8? Is this a track or street motor? What cams?
DZ12,935K3,934,2.8RSR
Ducati 900ss/GhezziBrian STW
dzugautomobili.com
Old 11-21-2008, 06:11 AM
It will have S cams or similiar. I need new or refurbed cylinders. Whats involved with a capacity increase to 2.8 ? i cannot afford new crank or rods and as you see the case is done?
Old 11-21-2008, 02:23 PM
Max Sluiter
Flieger's Avatar
70.4mm stroke crankshaft and 92mm Nickasil cylinders = 2.8
Or, with unlimited $$$$$$, you can get a rare 1974 Turbo Aluminum case and use bigger cylinders with the Supertech Supercrank with a 66mm stroke and build a high rpm screamer.
Old 11-21-2008, 02:42 PM
up-fixing der car(ma)
YTNUKLR's Avatar
Send a message via AIM to YTNUKLR
Line bore?
Scott Kinder
kindersport @ gmail.com
Old 11-21-2008, 03:05 PM
7r cases
I didn't line bore since we set it up on an industrial inspection table and measured the bores at the mains and the diameter of the mains. They are concentric , parrellel and consistent in diameter to within three thou ( worst total arror). at stable temperature of 22 deg c.
I reckon that it'll be ok at that ?
My crank is the standard from a euro 2.7 S is that the correct throw for 2.8. Can my existing mahle cylinders be used to get to this capacity ?
Old 11-22-2008, 01:23 AM
YTNUKLR's Avatar
If your line-bore is good then that's great...just not common... some have issues with the crank binding upon assembly...mostly due to the fact that the bores are not parallel anymore
That crank is correct for a 2.8RSR type motor. You can use your cylinders but they need to be bored, and replated, at 92mm. then you'll need the pistons to match.
The case looks good!
Scott Kinder
Old 11-22-2008, 02:03 AM
7R cases
Brilliant, I just spoke with the machine shop and they think the case may have been bored previously , guess I'll never know except that it measures true which I suppose is the most important.
Since I have the correct crank and already need to get the cylinders replated I may as well go to 2.8. The only additional cost will be the cylinder boring.
I intend using JE pistons will they be able to provide the correct size if I just say 2.8 capacity on a 2.7 crank . Then I can get the cylinders bored and plated to suit ?
andy
Old 11-22-2008, 04:27 AM
Andy
You can quickly check the case bores by installing the crank and bearings with some assembly lube, torquing down the through bolts and ensuring the crank turns with without binding.
Tom Butler
1973 RSR Clone
1970 911E - Sold but Never Forgotten
914-6 GT Clone
Old 11-22-2008, 04:36 AM
Max Sluiter
Flieger's Avatar
JE pistons are made from a different alloy than Mahles. The JE pistons will have excess clearance when cold in Mahle cylinders. For less noise and wear, use LN Engineering "Nickies" cyliders which are matched in expansion rate and clearances to the JE pistons. The "Nickies" are Aluminum alloy milled to superior specs than the Mahle cast cylinders. They both have the same Nickel-Silicon-Carbide coating in the bores.
Old 11-22-2008, 04:04 PM
YTNUKLR's Avatar
It's very easy to spend other people's money, isn't it.
Sure that is a superior solution, it should be when they cost 3x as much as replating and boring the old ones.
Scott Kinder
Old 11-22-2008, 04:57 PM
juicersr's Avatar
I'm building a 3.2 using mahles and 9.8:1 JE's. I think you'll be happy hassad with this combo in ur 'budget' 2.8 screamer. Keep us posted on the build!
Old 11-22-2008, 06:01 PM
3 restos WIP = psycho
kenikh's Avatar
Apparently JE offers pistons in different alloys now to accomodate cylinder choice. I still went the Nickie route...even Mahle's cylinders don't compare.
- 1969 911S
- 1980 911SC Targa
- 1979 930
Old 11-22-2008, 09:17 PM
Wer bremst verliert
JohnJL's Avatar
Looks good. What kind of oil pump are you planning on? Some choices require additional grinding...
2007 911 Turbo - Not a toy
1985 911 Cab - Wife's toy
1982 911 3.2 Indiash Rot Track Supercharged track toy
1978 911 3.0 Lichtbau toy "Gretchen"
1971 911 Targa S backroad toy
Old 11-22-2008, 10:03 PM
I have the later oil pump with the bigger volumes as recommended by Wayne. It fits my cases so I think thats ok.
The alloy drive gear from the crank is slightly worn having a small burr raised on the edge of each tooth . Is there a backlash tolerance or is this normal too
Thanks for the advice about cylinders. My finances only stretch to the re-use option with my cylinders . But I will make sure I get compatible materials for the pistons . I am tempted to use superseal rings , friends have good experience of them in Imp engines any opinion here?
The heads are being twin plugged at present.
Old 11-23-2008, 04:17 AM
I haven't heard this before. Is it generally accepted the JE/LN Eng. combo is "better" than the Mahle P/C set?
Sherwood
Old 11-23-2008, 11:58 AM
Max Sluiter
Flieger's Avatar
Sherwood
Yes. Just look at the beautiful CNC machining of the Nickies on LN Engineering's website. http://lnengineering.com/
Old 11-23-2008, 12:15 PM
Hello, Andy.
TBH . 3 though misalignment is significant is it not?
Yes the crank will flex and the oil will compress a bit so iot doeas not bind up totally..but I'm sure we commonly see the effects of this on strip-down..with one or more bearings being marked to one side..
what we don't see is the power losses this incurs..
I agree with the advice to check the crank spins freely..
Kind regards
david
Old 11-23-2008, 02:37 PM
Yes, very impressive. Any other objective reviews you can share?
Thanks,
Sherwood
Old 11-23-2008, 04:30 PM
Ok folks. I put the crank in with the old bearings and nipped it up to torque. The crank is free as a bird so all good advice noted. Reckon the cases are ok.
Still worried about the oil pump drive gear backlash, I measured about 12 thou' (0.3 mm) any views?
andy.
PS I'm convinced about 2.8
Old 12-01-2008, 04:23 AM
