idc1873
coxy's Avatar
3.2 engine rebuild, advice welcome
Doing a top end rebuild on my 3.2. more advice the better.
Rebuild thread on IB.
http://www.impactbumpers.com/forum/index.php?showtopic=7870&st=0
Old 12-03-2008, 12:46 AM
MBEngineering's Avatar
HI Coxy
your link will not work, as John has LOCKED the forum unless you log in.
top end parts you will need ; gasket set, rings, valve guides (exhaust), timing chains, chain rails,
Poss' parts; exhaust studs, head studs, cylinders/pistons, exhaust valves, intake manifold heat sink/spacers, fuel lines, cam feed pipes, fan belt, plugs, cams/rockers,
all this will depend on the mileage and driving usage of the car, the rings/pistons could be worn out,
I am not saying your rings will look like this, but if it is any where 100,000 miles thay could be.
regards mike
Regards mike
1983 911 SC sport, 1982 mini city
Old 12-03-2008, 01:11 AM
Recreational User
porschenut's Avatar
Best advice I can give is use Wayne's book as a guide.
Old 12-03-2008, 06:34 AM
+1 - and read and reread, and most importantly follow what it says. Get boxes and good zip lock bags and write down what the parts go to on a card and put in the bag... you think you will remember but you won't...even if you are young and don't have CRS.
Old 12-04-2008, 07:01 PM
