jasam's Avatar
Recommended piston rings
what manufacturer do you recommend me to buy?
I bought goetze and they are wrong, they just would not fit.
suggestions?
There is no substitute
Old 12-03-2008, 07:31 PM
Get the right Goetze rings for your pistons & cylinders.
You didn't say precisely what you have and what problems you are having so its tough to offer specific suggestions and solutions.
In some cases, the ring gaps must be measured and filed to fit.
Steve Weiner
Rennsport Systems
Portland Oregon
(503) 244-0990
porsche@rennsportsystems.com
www.rennsportsystems.com
Old 12-04-2008, 01:01 AM
jasam's Avatar
Sorry, my bad!
the problem is.....
the ring gap using the old ones is .016
the ring gap using the new ones is .019
the engine is a 2.2 E
Old 12-04-2008, 07:23 AM
Where (in the bore) did you make your measurements?
Sounds to me like you need to talk to your supplier about that situation as you may have received the wrong ones.
Steve Weiner
Rennsport Systems
Portland Oregon
(503) 244-0990
Old 12-04-2008, 09:30 AM
jasam's Avatar
I bought them from our host...
The print label says 85 mm std 2.2 lts
I just want to get the correct ones since in a previous post someone told me that the goetze are not as good as the used ones some times.
So... Shall I get a new set again??
Old 12-04-2008, 09:51 AM
There have been some QC problems with Goetze so you'll need to measure the thickness of the old rings and piston ring lands to see which ones fit best.
In some cases, I buy the parts from the Dealer as they are usually better than the aftermarket versions.
Steve Weiner
Rennsport Systems
Portland Oregon
(503) 244-0990
Old 12-04-2008, 10:47 AM
jasam's Avatar
The new ones are thicker and they feel stronger.. but with that gap they'll be useless so I want to get a new set.. but can you suggest me a place where I can buy them (which dealer)?
Old 12-04-2008, 05:39 PM
Any & all Porsche dealers source from the same place: the factory in Germany.
Choose the one you like.
Steve Weiner
Rennsport Systems
Portland Oregon
(503) 244-0990
Old 12-04-2008, 06:37 PM
jasam's Avatar
have you heard of mittelmotor?
Old 12-04-2008, 06:44 PM
Here's a couple places to try. You may need to open an account.
Last edited by 304065; 02-18-2009 at 05:39 PM.. Reason: thou shalt not post links to Wayne's Competitors on Wayne's board.
Old 12-05-2008, 02:48 PM
kodioneill's Avatar
http://www.deves.com/pricelist.cfm
try this
1974 sahara beige 911 targa
1982 chiffon 911sc
1985 prussian blue metallic carrera
Old 12-07-2008, 07:55 AM
jasam's Avatar
Deves rings dont fit nicer either... Should I get a new set of Goetze... I've checked mittelmotor, but I'm worried about that they might be the same as the old ones I got...
The first Goetze set had bigger gaps than they should, shall I install these no matter the gaps?
Old 02-18-2009, 02:34 PM
I think you just got a bad pair of Goetze rings. Actually, if you buy Genuine porsche rings, they are made by Goetze!!
I can recommend Mittelmotor. Great guys who know what they're talking about, but the rings from our host should be the same ones. Maybe a stupid question, but do you have STD pistons? If they are oversized....
I used Goetze and they fitted well.
Good luck!
Old 02-20-2009, 02:43 PM
