CIS conversion to Weber carbs
I have a 74 911S with CIS and want to swap to Weber carbs. I understand this change is pretty worthless unless you also change camshafts. Can anybody tell me which camshafts to use that won't require me to change pistons?
Old 01-05-2009, 07:32 AM
IMHO, you don't need to change cams, but it does help a bit.
You can use either early "T" cams or a 964 profile (ground on 3-bearing ones).
Steve Weiner
Rennsport Systems
Portland Oregon
(503) 244-0990
porsche@rennsportsystems.com
www.rennsportsystems.com
Old 01-05-2009, 08:57 AM
Try not, Do or Do not
Henry Schmidt's Avatar
Steve is correct. If you don't modify the pistons (IE: change or add valve pockets) your cam choices are very limited.
If you can modified the pistons, I would recommend Solex cams for all around fun street driving.
Henry Schmidt
SUPERTEC PERFORMANCE
Ph: 760-728-3062
Email: supertec1@earthlink.net
Old 01-05-2009, 09:34 AM
safe's Avatar
Would a T cam add any HP over a CIS cam? How does it compare to the 964 grind?
Magnus
Old 01-05-2009, 01:16 PM
