BURN-BROS's Avatar
MFI injector blocks for 3.2 heads.
Making up a batch as I post. These allow you to MFI your 3.2 based motor.
More pics to come...I still need to bore them and machine the injector ports.
Aaron. F.S. 1965 Solex engine w carbs/cleaner
Burnham Performance
https://www.instagram.com/burnhamperformance/
Old 12-21-2008, 02:18 PM
Can you make a set for 3.6L 3 stud heads?
I am buying if you do.
Clay Perrine
74 914 1.8L (Frodrick)
73 914 /6 4.0L 964 motor (Igor)
70 914 /6 Factory Six. (Elwood)
95 BMW 540i (Inga)
Old 12-22-2008, 11:18 AM
MBEngineering's Avatar
HI Aaron
do you mean, something like this??
MFI injector blocks for use with 3.2 heads???
would you like a set sending over??
regards mike
Regards mike
1983 911 SC sport, 1982 mini city
Old 12-23-2008, 01:13 AM
BURN-BROS's Avatar
Mike, hope all is well! I would have bought from you had I known you were making them as I needed a couple of sets. I'll keep you in mind when I burn thru these.
Burnham Performance
Old 12-23-2008, 07:16 AM
HI Aaron
I have 2 sets available now, 1 used and 1 set new. the ones on the post are the used set, (now back hear) which I had on a 3,0Lt engine with 3.2 heads and MFI.
regards mike
Regards mike
Old 12-23-2008, 09:53 AM
BURN-BROS's Avatar
STEP 2: bore out to 41.5mm
Burnham Performance
Old 12-23-2008, 03:35 PM
BURN-BROS's Avatar
Burnham Performance
Old 12-27-2008, 09:52 AM
BURN-BROS's Avatar
Burnham Performance
Old 12-27-2008, 11:16 AM
rs911t's Avatar
Does the additional height leave room for the air cleaner housing?
Greg
Old 12-27-2008, 01:17 PM
BURN-BROS's Avatar
Yes, height difference between SC heads and 3.2 with the spacers is about .25"
Burnham Performance
Old 12-27-2008, 01:33 PM
Try not, Do or Do not
Henry Schmidt's Avatar
Aaron, as usual your work is stellar. I look forward to owning a set. Now comes the haggling.
Henry Schmidt
SUPERTEC PERFORMANCE
Ph: 760-728-3062
Email: supertec1@earthlink.net
Old 12-27-2008, 05:22 PM
