MFI injector blocks for 3.2 heads.
Making up a batch as I post. These allow you to MFI your 3.2 based motor.
![]() ![]() ![]() More pics to come...I still need to bore them and machine the injector ports.
Aaron. F.S. 1965 Solex engine w carbs/cleanerBurnham Performance https://www.instagram.com/burnhamperformance/ |
Can you make a set for 3.6L 3 stud heads?
I am buying if you do.
Clay Perrine 74 914 1.8L (Frodrick) 73 914 /6 4.0L 964 motor (Igor) 70 914 /6 Factory Six. (Elwood) 95 BMW 540i (Inga) |
HI Aaron
do you mean, something like this?? MFI injector blocks for use with 3.2 heads??? would you like a set sending over?? regards mike
Regards mike 1983 911 SC sport, 1982 mini city |
Mike, hope all is well! I would have bought from you had I known you were making them as I needed a couple of sets. I'll keep you in mind when I burn thru these.
HI Aaron
I have 2 sets available now, 1 used and 1 set new. the ones on the post are the used set, (now back hear) which I had on a 3,0Lt engine with 3.2 heads and MFI. regards mike
STEP 2: bore out to 41.5mm
Does the additional height leave room for the air cleaner housing?
Greg |
Yes, height difference between SC heads and 3.2 with the spacers is about .25"
Try not, Do or Do not
Aaron, as usual your work is stellar. I look forward to owning a set. Now comes the haggling.
Henry Schmidt SUPERTEC PERFORMANCE Ph: 760-728-3062 Email: supertec1@earthlink.net |
