I would rather be driving
jpnovak's Avatar
My 3.2SS The final Chapter - It runs
First, a link to previous posts on the build. I rebuilt the top-end due to head stud failure.
3.2SS continues - Part III - the assembly
If you are just starting the engine specs are as follows.
1978 930/03 base engine
98mm Mahle PC set.
Measured 10:1 compression
DC 40-108 deg cams
steel head studs
Home-made twinplug distributor using Jaguar 12-plug cap and Burn-Bros. rotor. Thanks Aaron!
Twin-plug heads by G2 Racing. Thanks Craig!
Ceramic Thermal barrier coatings on heads and piston crowns
Dry-film lube on cams, rockers, rocker shafts, piston skirts, wrist-pins and every other moving part I could find.
TWM 3003 ITBs
MegaSquirt ECU (MSII-V2.2)
A few weeks ago I was able to get the motor back in the car. Last week I finished wiring up the motor only to find that my Crane optical trigger was not working. Late Thursday night I sorted it out. (Read: A new one was delivered by FedEx Ground).
So I connect the ECU, disable the motor, pull the top plugs and spin the motor with the starter. I was getting about 1.2-1.3bar of pressure off the starter. Enabled the engine by connecting the ECU and installing the plugs.
I was not expecting the motor to start right away. The motor took half-a-turn and fired to life. I was a little freaked out and shut it down quickly. I am not sure why. 10 seconds later I fired it up again. Once it was running I stabilized the map and it was loping along at 2100 rpm to break in the cam. It was running a too rich to explain the loping. After my 25 min cam break-in I made some more changes to the EFI map.
Here is the result:
now I need to reset the AFR at idle, balance the throttle shafts and lean out the acceleration enrichment.
I am so stoked right now. I don't know if the high is from the unburned fuel vapors or natural euphoria.
Not a drop of oil anywhere that I can find.
Old 12-20-2008, 11:09 AM
abit off center
cgarr's Avatar
Excellent: There is no better feeling, at our age!
Your brave setting up a video for the first crank!
______________________
Craig
G2Performance
Old 12-20-2008, 11:50 AM
jpnovak's Avatar
Truth be told that was after I did the cam run-in.
Old 12-20-2008, 12:00 PM
BURN-BROS's Avatar
CONGRATS, Jamie!
Aaron. F.S. 1965 Solex engine w carbs/cleaner
Burnham Performance
https://www.instagram.com/burnhamperformance/
Old 12-20-2008, 01:12 PM
boba's Avatar
So, this will be out on the New Years Run and the Hill Country Rally.
Look forward to seeing it in person, excellent work.
See you soon.
Bob
Old 12-20-2008, 03:17 PM
jpnovak's Avatar
Thanks guys. Yes, the plan is to have it on the road for the New Year's drive. I need lights, door panels and seats.
Bob, Are you headed down for the drive? We could find a location to meet off 281 if you want to come the back way.
Jamie
Old 12-20-2008, 03:26 PM
boba's Avatar
I just saw the e-mail so I have not yet had time to check schedules, but I will try to fit it in. Will let you know.
Old 12-20-2008, 03:31 PM
Morrie's Avatar
Woohoo!
68 912 Coupe, 76 914 2.0 backdated, 76 912E SR Coupe"
Gone but remembered- 76 911S SR Coupe "The Clown Car", 89 944S2 SR Coupe, 76 912E "Green Rat", 67 912 outlaw, 68 912 Coupe, 87 924S
Old 12-21-2008, 04:07 PM
120 HP/Liter is all I ask
Days like this are what it is all about!! I feel sorry for those who do not play the game.
Old 12-23-2008, 08:39 AM
Crusty Conservative
silverc4s's Avatar
Jamie,
Congratulations! i can't wait to share the road with you on the 3rd. I sure hope the weather holds...
That is a really impressive project. I know you have untold sweat equity in that machine. You can be justly proud when your lap times pay the dividend for your work.
Bill
69 911 T Targa, 2.4E w/carbs (1985-2001)
70 911 S Coupe, 2nd owner (1989- 2015)
73 911 T Targa, 3.2 Motronic (2001- )
Old 12-28-2008, 02:20 PM
