Manassas, VA
lucittm's Avatar
Thoughts on Fan Finishes
Hello All,
I have seen a variety of finishes on our cooling fans. Everything from polished aluminum to powder-coat. Is there a consensus which is best or is it just a matter of taste?
Is there a weight advantage to having no coating at all?
This discussion is prompted by the peeling factory coating on my fan. Is this a common problem? Should I remove it? What is the best way to take it off?
Thanks,
Mark
1991 964 Polar Silver Metallic Turbo Coupe
Old 12-04-2008, 09:30 AM
From what I can see in your pic you're not looking at the factory finish...that looks like paint or something. I'd think paint remover would make pretty short work of that. From prior posts painting tends to be hit or miss, depending on prep and other factors. The housing looks to be pretty clean, at least compared to what mine looked like!
...edit, just noticed it looks like you've upgraded to a serpentine belt...how's that working for you?
Buck
'88 Coupe, '87 Cab,
'88 535i sold, '19 GLC 300 DD
Warren Hall, gone but not forgotten
Old 12-04-2008, 02:17 PM
OldTee's Avatar
Mine.
Old Tee
all 911s sold
Old 12-04-2008, 06:36 PM
user & abuser
that is a cool combo i have never seen!
i have a secret one coming next time mine comes off (this x-mas maybe)...
N
vini vidi vici
Old 12-04-2008, 11:58 PM
Air Medal or two
afterburn 549's Avatar
Base coat clear coat works just fine for me !!
D troop 3/5 Air Cav,( Bastard CAV) and 162 Assult Helicopter Co- (Vultures) South of Saigon, U Minh Forest, Delta, and all parts in between
Old 12-05-2008, 10:05 AM
al lkosmal's Avatar
fan coating
I've had the best luck with powder coating. This pic is after approximately 2 years of use on two different engines.
RGruppe #669
http://www.x-faktory.com/
Old 12-05-2008, 03:36 PM
Max Sluiter
Flieger's Avatar
Remember, powder coating is thick, so tell the coater not to coat the tips of the blades and part of the inside of the housing; otherwise you will have interference issues due to the precision clearance between the fan and housing for maximum flow efficiency.
I would polish and just let it oxidize. Even powder coating will not stop Magnesium from oxidizing. It just slows it down and makes it harder to see.
Any coating will need to be refreshed often in order to retain the "like new" finish.
Old 12-05-2008, 03:47 PM
Wer bremst verliert
JohnJL's Avatar
Powder coating is the only thing that lasts for any measure of time.
I wouldnt bother giving the powdercoater any special instructions, you might end up with a splotchy coat, not doing the front or something else silly. 2 minutes with some sandpaper will remove the powdercoat from the tips. That does the trick.
Also, mag does corrode but this is only an aesthetic fix. Ive never heard of anyones fan oxidizing into powder...maybe another 300 years...
2007 911 Turbo - Not a toy
1985 911 Cab - Wife's toy
1982 911 3.2 Indiash Rot Track Supercharged track toy
1978 911 3.0 Lichtbau toy "Gretchen"
1971 911 Targa S backroad toy
Old 12-06-2008, 06:50 PM
al lkosmal's Avatar
powder coated fan and housing II
No special instructions, just powder coat and go. Tip sanding may be required, but leaving the housing partially coated was not required (as you can see in this photo). No big deal and lasts a long time.
RGruppe #669
Old 12-06-2008, 07:08 PM
Schwarzeritter's Avatar
Location: PaloAlto Calif, IndianWells PalmDesert, Japan
Do be perfectly honest, in my own experince I have to say that it really does play into
the individual who is preforming the powdercoating. I have had some very excellent beautiful
work done and some that were very sketchy.
Typically I have never had a problem as over the
years I have found individuals or companys here in California who provide a good service and
we have a good company to company business relationship.
I have not had any issues or problems with cooling or too much paint being applied,
with a Porsche platform. I think also the paint to clear coat ratio is perhaps important.
^_^
Taze em..TAZE EM ALL!!
A man that builds a thousend bridges is a bridge builder, but a man that sucks one ( blank ) is a ( blank ) sucker.
It looks like the 4th of July from my rear view, how about from your view?
Old 12-06-2008, 10:33 PM
OldTee's Avatar
My daughters 87. Works for her.
Old Tee
all 911s sold
Old 12-07-2008, 05:50 AM
Forced Induction Junkie
WERK I's Avatar
I think when it's time for replacement of the mag pieces, I'm going for the aluminum reproduction pieces ( that is, if the quality control is there ), have them anodized and be done with it. Anodizing is low-maintenance and it's damn near bullet-proof. I've got better things to do other than spending 4 hours polishing a fan/housing.
Dave
'85 930 Factory Special Wishes Flachbau
Werk I Zuffenhausen 3.3l/330BHP Engine with Sonderwunsch Cams, FabSpeed Headers, Kokeln IC, Twin Plugged Electromotive Crankfire, Tial Wastegate(0.8 Bar), K27 Hybrid Turbo, Ruf Twin-tip Muffler, Fikse FM-5's 8&10x17, 8:41 R&P
Old 12-07-2008, 07:29 AM
Air Medal or two
[QUOTE=JohnJL;4344700]Powder coating is the only thing that lasts for any measure of time. End of Quote.
Not sure what you base your authority on........but in my case you are wrong,
What is your measurement of "time" ?
Mine is base coat clear coat, been at least 5 years..did it my self ( as the rest of the car ) Looks great, and still purrrrfect !! Best part is did not cost me a arm and leg as I did it same color as the car with (left over ).
So........I would not discourage this route at all
Old 12-07-2008, 10:40 AM
Friend of Warren
I used Kmart Krylon paint on my fan. 20,000 miles later and it still looks good.
Kurt V
Old 12-08-2008, 06:46 AM
idc1873
coxy's Avatar
[QUOTE=lucittm;4339663]Hello All,
Lots of options to go with, its up to you.
Old 12-08-2008, 11:16 AM
Manassas, VA
lucittm's Avatar
88911coupe,
I should have tried some paint remover when the engine was apart. Don't most of them say not for use on aluminum though?
As far as I know my fan is stock. The serpentine belt came standard on the turbo cars. I do like the polished and clear coat option. I believe that form follows function and the purpose is for the fan to move air and not induce drag due to a rough or irregular surface. Also, the powder coat has to add some weight. I wonder how much and would it affect the balance?
Thanks,
Mark
Old 12-09-2008, 10:01 AM
Mark, I'm pretty sure it's magnesium, although you bring up a good point about paint remover. It may not be good for magnesium either. I'm sure some of the metalurgists/chemists can enlighten us on this issue.
Buck
'88 Coupe, '87 Cab,
Old 12-09-2008, 10:52 AM
Powder coating is a broad generalisation and depending on the material being applied it may last quite well of fall off after a realtively short time.
I think that the best 'powder coating' for magnesium or aluminium used in an engine bay would be to use a proprietary nylon such as Rilsan.
Magnesium parts should be chromated before coating as this will ensure good adhesion and give excellent protection.
Aluminium could be pre-treated with either an Alobrite1000 or Alobrite1200 which is a slightly different chromate treatment.
Nylon is good because it is oil, petrol and brake fluid resistant.
Coatings can be either electrostatically sprayed or dipped using a fluidised bed.
Old 12-12-2008, 09:17 AM
Manassas, VA
lucittm's Avatar
coxy,
Is that your engine? It is a work of art. Can you enlighten us on how you made those pieces so shiney? Is there some chrome plating involved? What finish did you apply to the fan? I see that the air valve is polished, did you seal it with a clear coat? How about those hose clamps...
Mark
Old 12-12-2008, 06:56 PM
zugelassener benutzer
teamfee3's Avatar
I wish I went with the matte gold finish.
Team Fee '86 Carrera 3.2 Coupe blk/blk, no wing
7&9x16s BFG GForce SS 205/55 & 245/50s, SW Chip, Maxspeed catbypass, B&B, Sachs Power Clutch, Turbo mounts, oil cooler scoop, RS door panels, Momo Prototipo, Rennline fully adj gas pedal & floorboard, RS replica dead pedal, Weltmeister yellow h/l lenses, factory short shift, custom speedo
32C #7
Old 12-12-2008, 09:16 PM
