andrew15's Avatar
Odd P&C's from 3.2 L
I was just look on my shelf and found an odd set of P&Cs from a 3.2L.
With both P&Cs being marked KS, I assumed they were alusil cylinders and onto the shelf they went, but....
Cylinders have a groove for a CE ring gasket
Cylinders are nikasil (magnetic)
Pistons are not magnetic (like the iron coated ones for alusil cylinders)
Pistons have a 23mm wrist pin (so they are 3.2 not 3.0 pistons)
Did KS make a nikasil 3.2L P&C set with CE gasket?!
I have a receipt for an engine rebuild that specifies 'replated cylinders' which may explain the cylinders - maybe they are replated 3.0 versions. But that doesn't explain the pistons eing KS and suitable for nikasil.
Andrew M
1970 911E - track / weekend car
1970 911S - under restoration
1986 930 Slant Nose - fun car
Current used parts for sale
Old 01-05-2009, 10:19 PM
Andrew
What are the P/N's cast into the inside of the skirt or bottom of the dome?
That can help identify the pistons.
Tom Butler
1973 RSR Clone
1970 911E - Sold but Never Forgotten
914-6 GT Clone
Old 01-06-2009, 02:27 AM
