Chain fence eating turbo
Awesome info guys, learned some new stuff!
Cory - turbo'd '87 C3.2 Guards/Blk, 3.4, 7.5:1 CR, 993SS cams, Borg-Warner S366 turbo @ 1.2-1.5 bar, Treadstone full bay IC, 70mm TB, TiAL F46 WG, HKS 1 1/2" BOV, twin 044 pumps, MicroSquirt AMP'd w/GM smart coilpack, Bilstein coilovers, Tramont replica Speedlines (285's rr, 225's frt), Big Reds frt, 993 rr., tower brace, MOMO wheel Last edited by Tippy; 01-24-2009 at 05:50 PM.. |
Is there a way to guage by year (on an SC), or is it pretty much a crap shoot? Just curious.
Todd
'81 SC |
The Mahle stiffening rib was introduced later in the SC production run, but I am not sure which year.
Tom Butler 1973 RSR Clone 1970 911E - Sold but Never Forgotten 914-6 GT Clone |
abit off center
I bet if you were rather inventive you could somehow get a magnet down thru the spark plug hole and tell?
______________________ Craig G2Performance Twinplug, head work, case savers, rockers arms, etc. |
Guys, thanks for the wealth of knowledge. Tom, thanks for the pictures.
Andy
83 SC |
Twins are more fun!
Can Alusils be bored out and replated in Nikasil?
James Carrera TT (3.3, Protomotive MAP ECU, EFI, GT2 EVO CAMs, Twin Plugged, Twin Turbo's) |
3.4 Bigger is better
Yes they can. EBS is just one of the places that can do it for you. Give Don a call for details. LN Engineering is another that can do it for you, call them and Charles Navarro can answer your questions.
Michael 88 911 Diamond Blue CE Carrera 3.4 HC3.4 member 2020 Honda Passport |
disband
this thread has clarified otherwise what was/could have been a big delay in my upcoming rebuild with the whole niki v alusil determination at tear down. so, i have a very, VERY early US spec SC (according to engine cereal # the 82'nd 3.0 production motor) and the current cylinders shown below are the more desired niki's as i count fins & exterior finish. have not done the magnet test, but i see niki's by the info contained here. can anyone check my count and confirm my hopes?
![]() has my 1st hurdle been cleared? TIA toby
78SC PRC Spec911 (sold 12/15) https://www.youtube.com/watch?v=f7I6HCCKrVQ Now gone: 03 996TT/75 slicklid 3.oL carb'd hotrod 15 Rubicon JK/07.5 LMM Duramax 4x/86 Ski Nautique Correct Craft |
Toby,
I don't know about the number of fin stuff, but many people do seem confident in it so hopefully that means you have nikasil. I do know that your cylinders have a finish that looks like nikasil. Once you see an Alusil you can see a difference. The Alusil cylinders look shiney like they have glass in them (because they do). Nikasil has a dull grey finish on the outside. Alusils look different because they are not coated, they have the same alloy on the inside and the bore is treated by honing instead of coating. In any case if you do end up with problem cylinders (or worn out cylinders), you can usually get a good set of used cylinders for around 500 dollars. -Andy
72 Carrera RS replica, Spec 911 racer |
disband
Andy, hope you are well. i believe im in good shape after seeing an old set of alusils today at a local shop. the difference you refer to is very noticeable between the two. see you at the races this weekend
I am searching for a set of 95 M 9.3 Nikisals for my 83sc. Any idea where I can you find them?
My Alusils are worn My post WTB set of Mahle 9.3 P&Cs -------------------------------------------------------------------------------- WTB good set of Mahle 9.3 P&Cs The casting number inside the piston for Mahle is 95L67. Last edited by roadster49; 11-23-2012 at 11:50 AM.. |
Try not, Do or Do not
Henry Schmidt SUPERTEC PERFORMANCE Ph: 760-728-3062 Email: supertec1@earthlink.net Last edited by Henry Schmidt; 11-23-2012 at 03:56 PM.. |
And then there are these.......
Nikasil plated Alusil. Just in from Don at EBS.
