moneymanager's Avatar
Nikasil and Alusil
Am reading your book Wayne. Excellent. I should have gotten it a couple of years ago!
A question: you point out that the factory mixed Alusil and Nikasil pistons and cylinders in the mid 70's. Is it possible to determine reliably which I might have before pulling the engine? Might the magnet test work under the car? Or is there a possibility that one of the cylinder markings might be visible from underneath (or anywhere else?) Thanks,
jhtaylor
santa barbara
74 911 coupe. 2.7 motor by Schneider Auto Santa Barbara. Case blueprinted, shuffle-pinned, boat-tailed by Competition Engineering. Elgin mod-S cams. J&E 9.5's. PMO's.
73 Targa (gone but not forgotten)
Old 01-23-2009, 04:19 PM
UFLYICU
ZOA NOM's Avatar
Send a message via Yahoo to ZOA NOM
There are exactly 11 heat fins on the Nikasils, while the Alusils have exactly ten. You can put the car on a lift, or simply jack it up high enough to crawl under and find a spot where you can count them on the bottom of the motor.
_______________________
Racer Rix Spec911 #5
prc-racing.com
Old 01-23-2009, 04:34 PM
Really? It's even easier than I thought. Thanks!
jhtaylor
santa barbara
Old 01-23-2009, 04:36 PM
UFLYICU
ZOA NOM's Avatar
It took me a few minutes, but I pulled a Nikasil from my race car, and an Alusil from my Daily Driver and took a pic for you.
prc-racing.com
Old 01-23-2009, 05:03 PM
Gosh. It would have taken me at least an hour to do all that. And you got them pretty clean too. Thanks again.
jhtaylor
santa barbara
Old 01-23-2009, 05:16 PM
abit off center
cgarr's Avatar
Here is a Nikasil and an Alusil, Which one is which?
Craig
G2Performance
Old 01-23-2009, 05:56 PM
Try not, Do or Do not
Henry Schmidt's Avatar
The one on the right with the fin support is the Alusil.
Henry Schmidt
SUPERTEC PERFORMANCE
Ph: 760-728-3062
Email: supertec1@earthlink.net
Old 01-23-2009, 06:39 PM
abit off center
cgarr's Avatar
Yep, (the support!)
Craig
G2Performance
Old 01-23-2009, 06:58 PM
UFLYICU
ZOA NOM's Avatar
So, why does my Nikasil have the fin support? Am I missing something?
prc-racing.com
Old 01-23-2009, 07:03 PM
The cylinders you posted are 95 mm and the cylinders posted by cgarr are 90mm.
Mahle decided that the fin supports first offered by KS were a good idea and copied the design.
Henry Schmidt
Ph: 760-728-3062
Old 01-23-2009, 07:28 PM
UFLYICU
ZOA NOM's Avatar
Oh, thanks Henry. *Whew*
prc-racing.com
Old 01-23-2009, 09:43 PM
But aren't we looking at an Alusil with 11 fins AND a Nikasil with the same number? I'm confused.
jhtaylor
santa barbara
Old 01-23-2009, 09:48 PM
It looks like your 90mm cylinders could have 11 fins with Alusil or Nikasil. I don't know if the fin support is difinitive for your car or not. Notice in the pictures that the cylinders have a distinctly different look to them. The Alusil has a shiny finish almost like someone sprayed clear paint on them. The Nikasil has a standard dull aluminum look. Of course it's easier to tell when looking at them togther but you should be able to tell by this finish. The Alusil basically has glass crystals in it and the material goes all the way through. The Nikasil just has a thin coating on the inside of the cylinder. The outside is just aluminum.
-Andy
Old 01-23-2009, 10:22 PM
UFLYICU
ZOA NOM's Avatar
Yeah, I'm sorry moneymanager, I should have noticed the difference in the years of our cars. I think my assertion about the number of fins is consistent for the Carreras, but I don't know about other years.
prc-racing.com
Old 01-23-2009, 11:41 PM
For the mid 70's motors, 90 mm bore/2.7 liters, the factory used (3) types of cylinders. These were:
1. Mahle Alusil
2. Kobelschmidt (KS) Alusil
3. Mahle Nikasil
The pics below show that all had 11 fins and the only KS had the rib. If we are talking about 2.7 motors, the Mahle Alusil and Mahle Nikasil are almost identical in appearance from the outside. The only way I know to tell the difference is to look at the appearance of the inner bore. The Alusil will have the matte grey appearance while the Nikasil will normally be more shiny or chrome-like. The definitive test is whether the inner bore attracts a magnet indicating Nikasil.
The 90mm/2,7 liter cylinder pics below show from left to right, Mahle Alusil, KS Alusil and Mahle Nikasil.
Tom Butler
1973 RSR Clone
1970 911E - Sold but Never Forgotten
914-6 GT Clone
Old 01-24-2009, 05:02 AM
On the 95mm 3.0 SC cylinders, there were also 3 variants:
1. Kobelschmidt (KS) Alusil with rib/10 fins
2. Mahle Nikasil with rib/11 fins (late SC)
3. Mahle Nikasil without rib/11fins (early SC)
All KS cylinders have the rib and have 10 fins. Mahle adopted the rib later in the SC production run and carried the rib over to the 3.2 95mm cylinders. All 95mm SC Mahle cylinders have 11 fins.
So....On an SC it is possible to tell the difference between Alusil and Nikasil by counting the fins, but not by the presence of the rib.
The pics show left to right. KS Alusil, Mahle Nikasil late with rib and Mahle Nikasil early no rib. Ignore the moon cuts at the base of the cylinder on the early SC (it is a non factory performance modification).
Tom Butler
1973 RSR Clone
914-6 GT Clone
Old 01-24-2009, 06:04 AM
So I think the long and short of it is you need to pull the motor apart and do the magnet test on the inner bore to know what you've got. I was really excited that I might just be able to slide under the car and find the answer before disassembly. Is that the consensus?
jhtaylor
santa barbara
Old 01-24-2009, 07:42 AM
If you've got a 2.7 you are correct.
If you've got an SC or a 3.2, you can count the fins.
Tom Butler
1973 RSR Clone
914-6 GT Clone
Old 01-24-2009, 08:56 AM
Manassas, VA
lucittm's Avatar
Could we get the same primer on cylinders for the turbo cars? To include the 930, 965, 996TT, and the 997. The level of knowledge on this forum is simply awesome!
Mark
1991 964 Polar Silver Metallic Turbo Coupe
Old 01-24-2009, 10:40 AM
All turbo cylinders are Nikasil.
The earliest 930 were full finned 95 mm. 3.0.
The next generation was partial finned 97 mm 3.3 .
The 965 had a 97 mm full finned cylinder. Also a 3.3
Next we get the 3.6, 100 mm cylinder. Most were cast but the factory made some billet versions. They look very much like Nickies.
At this stage, I'm out of personal information.
Henry Schmidt
Ph: 760-728-3062
Old 01-24-2009, 11:50 AM
